#31
| Sanded on the Trapeze dinghy today. This was the first time I’d seen it since the PC-11 had been applied. It was not as bad as I was expecting. He had done a good job of applying only a thin coat of the PC-11. I used 120 grit in the belt sander and wet sanded the PC-11 spots. Then covered much of the hull with the longboard to judge how we did. Overall the result is not bad. There are still a few low spots which we will use microballons/epoxy as a fairing compound on. The PC-11 is very hard! Sanding one thin coat worked out ok. I’d hate to try another application of the PC-11. Primarily because it is so much harder than the polyester fg. A light touch is required to grind the PC-11 without attrition of the polyester fg. |
#32
| Pratt & Lambert - Palgard Quote:
Does anyone have experience with this paint in marine applications? |
| How to make my own epoxy primer? | teakcell | Wooden Boat Building and Restoration | 27 | 11-25-2009 01:42 AM |
| epoxy primer | portpennscrabs | Boatbuilding | 4 | 12-30-2008 05:39 PM |
| Etch primer on epoxy? | Brands01 | Fiberglass and Composite Boat Building | 6 | 10-07-2007 04:59 AM |
| epoxy primer sprayed on green epoxy laminate? | bntii | Boatbuilding | 12 | 10-16-2006 06:41 AM |
| Epoxy Primer/Interlux | alexhiguera | Materials | 0 | 02-03-2005 05:09 PM |
