  #31
Old 02-22-2010, 04:01 AM
Axell Axell is offline
Rep: 10 Posts: 2
You can GL approved epoxy to very fair prices from ww.bodotex.dk in Denmark.
GL approved BPA/F in 20kg for just below 4 Eur/kg and curing agents to 6-8 Eur/kg.
Good luck
  #32
Old 02-23-2010, 04:03 AM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 383
Thanks for the suggestion Axell!
I think this is for bigger quantitys then I might need. But a very very good price though especially when it is certified products. I found their homepage also. Maybe it is interesting for those boatbuilders who uses a lot of this stuff.
http://www.bodotex.dk
Kind regards
Janne
The more I learn the more I do understand that I do not understand. :)
  #33
Old 04-10-2010, 01:51 AM
latman latman is offline
Rep: 14 Posts: 48
There are only a few BASE epoxies in the world(BASF and Shell make some)your local formulator buys these ,adds small amounts of "special ingredients" diluents, thickeners, wet-out aids or whatever and sells it to us. The Chinese fabricator usually just buys those base resins which are often thicker AND cures slower and uses things like heated moulds to get a good cure, It doesn't matter to the factory that the heat kills the moulds because there is then an endless supply of workers to sand a paint the products with isocyanate paints and primers and fix any print or distortions from cooked moulds.(it doesn't matter to anyone there that these paints are lethal)
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 02:56 PM
West System epoxy over D.E.R 331 epoxy bobbychuong Materials 8 10-18-2008 03:13 AM
epoxy primer sprayed on green epoxy laminate? bntii Boatbuilding 12 10-16-2006 06:41 AM
Epoxy sbklf Fiberglass and Composite Boat Building 8 04-30-2006 06:40 PM
Epoxy......how much i need? {NW}BKUSA Wooden Boat Building and Restoration 7 01-21-2005 05:14 AM
