| It's not wiring. It's structural. As I said before, I have an electrical engineer for this. All of the potential problems have been addressed in this area.
__________________ Sir Lurk-a-lot Someday I may build a dugout |
| But the Real Question is Would you use it in a Boat Would you use it under float Woould you use it on a Train or where it is under shaky vibratory strain Would you use it in a pinch when your life depended on every inch would you use it on a missle whilst the wind would make it whistle would you use it in your Jet? I would not use it, Not on a Bet, Not in my Jet, Not on my Boat nor underwater where I float. ![]() |
| Lol, that's the best laugh I've had all day. Did you make it up yourself? ![]()
| Advice on bonding to urethane foam | BobMan | Fiberglass and Composite Boat Building | 6 | 05-30-2009 10:51 PM |
| aluminum hulls+marine filler=issues | gforcepdx | Sailboats | 3 | 11-19-2006 11:16 PM |
| urethane foam in stringers | fishweed | Fiberglass and Composite Boat Building | 10 | 08-20-2006 10:32 PM |
| Foam for Insulation, not structure | pairomedicsfish | Materials | 5 | 07-06-2006 08:28 AM |
| polyester matrix over urethane foam | tjantti | Materials | 0 | 09-21-2004 04:21 AM |
