Old 09-07-2011, 10:07 PM
Michail Michail is offline
Rep: 15 Posts: 54
Elastometric foam spacers for bulkhead to hull joint
Are they structural or simply keep the bulkhead separated from the hull and the only structural element is the fiberglass tabbing which joins the bulkhead with hull?
Can a nonstructural spacer be used?
If they are structural, any suggestions for alternative materials?
Old 09-07-2011, 11:08 PM
Rep: 1493 Posts: 7,447
Any soft spacer will work. I have seen rope and bondo used. Foam with beveled edges is my preference.
Old 09-08-2011, 05:37 AM
Rep: 15 Posts: 54
Thanks again
Transition joint or full length butt joint unseen wombat Wooden Boat Building and Restoration 12 06-05-2011 12:16 PM
Deck To Hull Joint VIKING Boatbuilding 16 10-06-2008 07:57 PM
Sandwich hull panel to plywood bulkhead T joint??? leegrace Fiberglass and Composite Boat Building 4 02-01-2006 08:42 PM
Whats the strongest bulkhead joint leegrace Boat Design 10 01-30-2006 12:31 AM
Hull joint extrusion Lew Morris Sailboats 3 09-09-2005 08:45 PM
