Old 08-20-2009, 07:19 PM
scotch&water scotch&water is offline
Rep: 51 Posts: 46
Edge molding
Hi all you experts, having a problem locating edging strips for a wood boat rebuild project, transom chine edges ect. Boat is home constructed 50 years old ? Builder tacked and screwed galv. flashing on all edges and it looks tacky, my customer would like to replace them. Fritz
Old 08-25-2009, 09:48 AM
pescaloco pescaloco is offline
Rep: 19 Posts: 231
How about light guage stainless steel angle 2x2 of so
if the lines are not to curvey it should work fine with out much extra metal work
Old 08-25-2009, 11:53 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
Any sheet metal shop can make them, and also tig weld the joints if necessary. Ask for "food grade" stainless, which guaratees least corrosion.
Old 08-25-2009, 01:00 PM
Rep: 51 Posts: 46
edge molding
Thank you Pescaloco and Alan for you help, I have checked with the metal shop and 24G can be cut and bend the welding will be solved. Fritz
surface edge problem Multi600 Software 4 02-12-2009 06:16 AM
best leading edge? lunatic Boat Design 3 11-30-2008 11:14 PM
Mainsail leading edge slat. Omeron Sailboats 6 07-25-2007 06:44 PM
Edge Marine Outlaw Powerboats 1 12-13-2006 05:47 PM
Keel edge Phosphor Sailboats 5 09-06-2005 03:26 PM
