Old 01-30-2010, 02:35 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
No idea on the base materials (nuts are claimed), but as Richard already said, about anything can be made into epoxy. But what you get is epoxy. Which can be a health hazard.
Only advantage I can imagine is the "green" aspect. For what it is worth, of course. But that is another discussion.
Old 01-30-2010, 02:43 PM
apex1
Originally Posted by Boston View Post
to bad
would have been nice to have a non petroleum based epoxy
There are some on the market Boston. Mainly soya oil based.
Old 01-30-2010, 03:50 PM
Buildboats's Avatar
Buildboats Buildboats is offline
Rep: 15 Posts: 223
I just received their test result
File Type: pdf 9015-179 Summary Report one sample.pdf (130.4 KB, 150 views)
Old 01-30-2010, 03:58 PM
Buildboats's Avatar
Rep: 15 Posts: 223
they sent this also
Old 01-30-2010, 05:51 PM
apex1
Yeah, nice....
almost every common Ep. is free of "outgas" and "odor" also. And once fully cured they are inert too.
So, what makes this product outstanding? Nothing. Marketing drivel.
Regards
Richard
Old 01-31-2010, 06:22 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
ok
so my chemistry is a bit rusty
how does a non petroleum based epoxy work
and do they hold up to there more toxic ( one would think ) brethren
Dam I need to go read up on this one
I am skeptical of the deniers diatribe
Old 01-31-2010, 08:17 AM
apex1
ok
There is generally no difference Boston. The resin does not "know" if it is made from lard or oil. Once estered the chemical is neither more or less toxic, or more or less green. Thats all just marketing drivel.
Though some basic materials allow for products with a bit specific properties, compared with others, one can say, you could formulate what you need.
Regards
Richard
Old 01-31-2010, 10:40 AM
Buildboats's Avatar
Rep: 15 Posts: 223
really good conversation thanks for the contributions, I see it in a different light now. I got some coming and will infuse something with it. I don't want to get more sensitized... it's just beginning, after 30 yrs I guess I'm lucky to a point. I Know low Tox MAS resin helps with this, I was hoping this product might even be a little better? I can't infuse Low Tox Mas in whole, it requires infu-cure with a second hardenner... Ecopoxy this can be infused as it is.
Old 02-07-2011, 05:29 AM
Alex.A's Avatar
Alex.A Alex.A is offline
Rep: 65 Posts: 298
Any further information on this product?
Buildboats - any test results to share?
Wharram is building his new 27' eco fishing cat using it on one hull as a tester.....
They did say on the site that it is soya based.
Long shelf life also a plus.
  #25
Old 02-07-2011, 08:03 AM
Buildboats's Avatar
Rep: 15 Posts: 223
Nothing exceptional to post- besides the fact I have been using Eco-Poxy to infuse some panels to make a fly bridge for my 30ft cat, I was very happy with the flow and my eyes didn't react in any way. I get sensitive eye lids when using other resin. It is a proprietary product so should use all there products if you don't want to have to deal with mechanical adhesion between different stages of manufacturing. I haven't had an issue since I peel-ply everything
Eco-Friendly Materials?? bigalogigalo Fiberglass and Composite Boat Building 73 05-14-2008 04:12 PM
NEED HELP-wooden boad friendly in Chesapeake robert_mercer Boatbuilding 5 05-11-2007 03:51 PM
NEED HELP-Wooden boat friendly in Chesapeake robert_mercer Open Discussion: All Things Boats & Boating 0 05-06-2007 09:17 AM
what is the best and friendly-user 2D and 3D design software Falcon Boat Design 0 12-03-2004 01:44 AM
What is the most environmentally friendly propulsion system? dolphin300 Boat Design 26 11-14-2004 05:03 AM
