EasyCell75 Closed Cell PVC Foam
Jussi_2
Joined
Jan 5, 2014
Posts
18
Reaction score
Location
Finland
I bought EasyCell75 Closed Cell PVC Foam 25mm thick. I will test it with 2 layers of Biaxial Glass Cloth 600g to both sides. Does anyone has any experience with EasyCell? I will do vacuum infusion with epoxy. I will make 550mm x 545mm size panel. I can post photos if anyone is interested about it.
Density ISO845 Kg/m3 = 75
Compressive Strength ISO844 MPa = 1.33
Compressive Modulus ISO844 MPa = 72.5
Tensile Strength ISO527-2 MPa = 1.89
Tensile Modulus ISO527-2 MPa = 75
Shear Strength ISO1922 MPa = 1.09
Shear Modulus ASTMC393 MPa = 27.75
Shear Elongation at Break ISO1922 MPa = 20.25
Thermal Conductivity at Room Temperature ISO8301 W/mK = 0.033
Water Absorption % = 1
Colour:_ Green
Mechanical properties looks like to be close to GURIT CORECELL M80..
EasyCell75
Hi!
Please post on your results with EasyCell75 foam.
I have infused the 25mm easycell now.. 2 layers of 600gr biaxial fiberglass for both sides.. Very rigid!
Any suggest what kind of test I could do with it? Maybe best would be attach other side to something, and add something like 200kg in other end, and measure how much it bend.. Also I could try to hit something sharp, to broke the surface..
I have put 2 bricks to sides and sheet over it, and tried to jump over the sheet to get it bend, but no! It is very rigid.. I weight almost 80kg. I did compare it to 6mm solid fiberglass, and it bend..
Back
