| Dynel vs. Fiberglass - as wood strip sheathing What are the technical and practical advantages and disadvantages of sheathing a wood strip plank hull with epoxy/fiberglass vs. epoxy/Dynel? The sheathing should be considered structural, in addition to abrasion resistance. Searching the forums has brought up rather little. Thank you. Robert Miller |
| You can look at Gerr's book on boat strength. Dynel is a very loose weave so it takes a lot of resin to provide a smooth surface. |
| Dynel does cover compound surfaces much better then typical glass layups and provides more abrasion resistance then same. I'd skin the hull in glass and hold the final layer for Dynel if you really require the additional help. It depends on the layup schedule meant by the designer. Decks are an area you see Dynel for obvious reasons, but there are better materials available for abrasion resistance. What are you building? |
| Read a story about atrimaran in a collision,broke off 3 to 5' of port ama bow, dynel kept bow atached,minimal leakage. Boat saflt returned to port. |
| Dynel Sheathing Hi Robert Don't know if you have already been sorted out but I introduced Dynel Sheathing into the Far East 30 years ago. If you are definitely needing strength and not just protection Glass Cloth is obviously the way to go but Dynel does help a little. If you regard your hull strong enough for your needs I can assure you that Dynel is a great sheathing process. I sheathed 3 20M naval vessels 30 years ago and they are still operational today with the same sheathing on. People think they are constructed in GRP. Dynel being a polyester cloth is easy to use and non irritant. David |
| Dynel does not wet out clear. So it'll "fog" the look of a natural wood finish. |
| From what I have read Fiberglass can be too stiff for wood, and may delaminate. While Dynel or some of the other products from Defender Industries will be able to. If you are going to use fiberglass then you must use one of the more flexable epoxies. Thomas. |
| best low tox wood preservative | lofting4fun | Wooden Boat Building and Restoration | 3 | 08-27-2005 03:33 PM |
| how to fiberglass and varithane wood? | brendodendo | Boat Design | 2 | 05-12-2005 09:32 PM |
| Looking for wood species in Asia for strip planking | Daren | Boat Design | 33 | 12-09-2004 02:46 PM |
| Strip Planking wood | Friedrich | Materials | 9 | 12-03-2004 12:03 AM |
| Wood Sources in U.S. for strip planking | nero | Materials | 1 | 10-19-2004 12:03 AM |
