Old 01-15-2008, 05:52 PM
RoyB RoyB is offline
Rep: 10 Posts: 9
DuraKore as cabin floor?
I think I put this in the wrong category when first posted. Apologies to anyone bothered by re-post...
I will be replacing the cabin flooring in a 40 foot sailboat. The existing flooring is getting soft from moisture and abuse and the Teak and Holly veneer is trashed.
I've been thinking about using BalTek / DuraKore for the job. I'd laminate either thin Teak/Holly veneer (if I can find it) or else a layer or two of carbon fiber on the upper surface.
I have a some questions:
1) Would I be better off using balsa or foam cored material?
2) How do I best calculate the required thickness?
3) If I surface with carbon fibre I'd like to clear coat it for appearance. Is there a good way to apply some non-skid to the exposed surface without destroying the appearance?
4) Will epoxy work for the exposed surface or is it too soft and subject to marking if a winch handle or similar is dropped on it?
5) In general (I know it's hard to give a specific answer) will a DuraKore+surface laminate panel be lighter than an equivalent plywood + teak/holly veneer panel?
6) Is there another approach to the top surface that I haven't thought of that would be better than CF or veneer?
Thanks in advance
BalTek / DuraKore for cabin floor RoyB Fiberglass and Composite Boat Building 8 03-01-2008 11:07 AM
Cabin Ventilation darrenyorston Wooden Boat Building and Restoration 3 09-25-2006 10:00 PM
detachable cabin djwkd Boat Design 3 08-12-2006 05:36 AM
Cabin Floor replacement Cliff Ruckstuhl Materials 2 09-10-2005 04:25 PM
18-24' Cabin / Half cabin moulds Louis Boat Molds 0 07-27-2005 04:48 AM
