Old 12-30-2004, 05:27 AM
mojounwin mojounwin is offline
Rep: 10 Posts: 58
DuFLEX strip plank
looking to build a 26ft yacht strip planked, and stumbled across a product called Duflex which is essentially a foam core that is coated each side with 600gm biax E-glass. http://www.atlcomposites.com/pdf/DuFLEX_brochure.pdf
Has anyone used this product before?
How does it compare with using cedar as a core?
Because the core is already coated with fibreglass could you use a lighter cloth to cover then would be used to cover cedar?
Thanks
Mike
Old 12-30-2004, 05:48 AM
Rep: 700 Posts: 3,208
The biggest advantage would come at resale time,
boats with burried wood are hard to sell ,
even though they claim to be "Composite" ,
the public knows better.
FAST FRED
Old 11-30-2007, 12:05 AM
captainjsw captainjsw is offline
Rep: 24 Posts: 36
I am building with DuFlex - I see this is an old thread - if you are still interested in knowing more - let me know
Regards John
Old 12-04-2007, 06:34 AM
Willallison's Avatar
Rep: 2283 Posts: 3,468
FAST FRED
I think that's an attitude that's changing - especially as more and more large custom vessels are employing strip planking (wood, I mean). It's also a bit of a regional thing - the Kiwi's, for instance, don't share any fear of timber cored boats.
It's also somewhat ill-informed - a poorly built foam or balsa cored boat is every bit as prone to wet core damage as a poorly built strip plank boat is - if not more so.
Will
Imaginocean Yacht Design
www.imaginocean.net
Speed Strip tongue-and-groove strip planking Jeff Materials 38 08-05-2009 12:12 AM
plywood vs strip planking jfblouin Materials 2 03-08-2005 03:55 PM
strip plank technique pingert Wooden Boat Building and Restoration 7 07-24-2004 02:58 PM
Epoxy versus Cascamite & compatibilities Peter2004 Wooden Boat Building and Restoration 3 06-23-2004 08:00 AM
strip plank construction jimo Sailboats 2 05-26-2004 06:11 AM
