Old 09-26-2009, 09:04 PM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
Double "strip planking" Core-Cell
I have a substantial amount of 1/2" Core-cell but have some areas that I would like to be 1" thick. Does anyone know was the procedure is for laminating one layer of Core-cell on top of another? Can this be done? My initial thought is a slightly thickened epoxy but I've spent the afternoon on the Core-cell site and elsewhere on the web and can't verify this. Any thoughts?
Old 09-29-2009, 09:01 AM
Bentwood Bentwood is offline
Bentwood
Rep: 10 Posts: 21
I laminated 2 layers of 1/2" corecell together for the deck and cabin cores of my 32' sailboat. I had the "pin-hole" variety of corecell that allows air to get out and glue to leak into the bond. I used epoxy thickened with microballoons and colloidal silica, spread on both surfaces with a notched trowel. It is very important to get an even gluing pressure across the entire surface. Vacuum bagging works best. Other alternatives were to screw the corecell to frames with plywood strips to hold the screw heads.
Old 09-29-2009, 01:07 PM
Rep: 112 Posts: 211
Many thanks Bentwood! You have described my exact situation and my ideas of how to deal with it. I will proceed as you have suggested.
Old 09-30-2009, 11:49 AM
Rep: 1397 Posts: 7,215
Firstly, are you using solid sheets or scored? Secondly, you should bond the sheets with the same resin you will laminate the skins with.
Old 10-01-2009, 01:00 AM
Rep: 112 Posts: 211
Gonzo,
My plan was to use thickened epoxy as noted above...the same as tabbing and deck laminate. The core-cell is kerfed.
Old 10-01-2009, 02:42 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
please fill the kerfs. If the stuff is knife cut without scrim, press it over a curved surface, and apply resin. Turn around and do the other side as well.
With the scrim cloth version, one side bending and filling is enough. Then bed into the core bedding compound. (can be epoxy with fillers added)
Old 10-01-2009, 09:16 PM
Rep: 112 Posts: 211
Herman,
Yes it is knife cut. I will do as you have suggested, thanks.
Old 10-03-2009, 10:36 AM
Herman's Avatar
Resininfusion.info
Actually this procedure is described in "Core-Cell Design Manual" which was publised by ATC Chemicals, but unfortunately it disappeared when Gurit took over.
Old 10-09-2009, 04:11 PM
mikereed100 mikereed100 is offline
Rep: 30 Posts: 82
ATC/Gurit make a product called "Corebond" formulated specifically for this purpose http://www.noahsboatbuilding.com/noa...cbb705&eq=&tp=
Mike
Old 10-11-2009, 04:33 AM
Herman's Avatar
Resininfusion.info
This can be done in a number of ways, and with a range of materials. Basics are that a laminating resin is applied on both sufaces, and a thickened resin for the actual glueing. Pressing things down (vacuum) helps getting a good bond.
Old 10-12-2009, 12:16 AM
Rep: 112 Posts: 211
Mike,
Thanks for the note about Core-Bond and the link to Noah's. I purchased the Core-Cell from Noah's and have considered using the core-bond, but I'm purchasing epoxy for all of the laminating and tabbing and thought it best to try to use an epoxy product for the lamination of the core-cell itself. Just one less variable in the mix.
Herman,
Do you know of an epoxy based product simialar to the Core-Bond Mike mentioned?
Old 10-12-2009, 04:03 AM
Herman's Avatar
Resininfusion.info
I am not familiar with products available in the USA. In Europe the company Sicomin has some nice bonding pastes, based on epoxy.
Old 10-17-2009, 12:42 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
Old ATC webpage was still running last time I checked and had some tech pdf files, possibly the one you mention, at least something on the use of the corebond.
but i dont remember the adress any more.
Old 10-18-2009, 07:06 AM
Herman's Avatar
Resininfusion.info
It was atc-chem.com, but that brings you to the Gurit website now.
"Best" foam core dshowalt Materials 13 03-29-2009 09:37 PM
redesigning Atkins' "Joan" for strip planking vjt Boat Design 13 01-18-2009 01:14 PM
"best value" core material rapscallion Fiberglass and Composite Boat Building 2 03-17-2008 08:13 PM
Balsa core "filler" rturbett Fiberglass and Composite Boat Building 3 10-13-2005 08:48 AM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
