View Poll Results: Do you follow Around Alone?
Yes everyday! 1 9.09%
Pretty often at least once a week 1 9.09%
Once in a while, just to see what's going on 5 45.45%
No, never 4 36.36%
Voters: 11. You may not vote on this poll
Old 01-12-2003, 12:38 PM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
Delamination question...
Bernard Stamm who's currently participating in Around Alone, just arrived in NZ with quite a nasty delamination in what looks like the outmost carbon layer of the outer laminate skin.
But should a carbon fiber laminate really delaminate this way "just" because of waves and slamming? Prette severe weather on the way over, sure, but shouldn't the epoxi keep the carbonfiber layers together better?
What are your opinions on this? Bad craftsmanship or just a result of the construction choosen?
My thought is that it shouldn't look as smooth as it does in the delaminated area, doesn't that indicate a weak bond from the very beginning in the laminate?
BTW do you follow Around Alone?
Erik
Old 01-14-2003, 08:56 AM
tgundberg tgundberg is offline
Rep: 10 Posts: 19
The delam is probably due to the high fiber to resin ratio used in these types of racing boats. They might have been trying to "squeeze" out as much resin as possible to save weight, which reduces the interlaminar bonding. Once a tiny crack (or stress concentration) evolves, the constant wave attack simply propagates the crack down the path of least resistance....the interlaminar bond. I have heard of some vessels with this problem incorporating "peel stoppers" in there skins, so when a layer does delam, the damage is localized.
Old 02-05-2003, 11:04 AM
Rep: 1397 Posts: 7,215
I think the amazing thing is that after all that delamination the boat is still afloat and sailing.
Hull enlargement question?? jackason Boat Design 3 09-09-2005 08:03 PM
Fiberglass Hull Liner Question Seadog Fiberglass and Composite Boat Building 7 08-14-2005 07:42 PM
Question re: "Voyaging Under Power" ccollar Boat Design 1 01-22-2005 06:43 AM
I/O to Inboard Conversion; DWL Question MDuff Powerboats 7 11-23-2004 05:04 AM
Planing hull question graham Boat Design 10 12-13-2001 05:40 PM
