| Deck coating to use over epoxy and fiberglass I repaired the damaged deck area of my boat with epoxy and want to recoat the entire deck. What can I use to recoat over both the old gelcoat (I can tell it is poly something when I sand it) and the epoxy areas? |
| I am currently about to paint the deck of my sailboat. I will use Interlux Brightside single-part polyurethane. I will lay down the first finish coat and spinkle non-skid onto it, and let that dry, and then add one or two coats over. If you want to spend double, for a job that lasts twice as long, use a two part ployurethane. On a deck, this could make sense. If using non-skid, an ultra-smooth finish and spraying aren't needed. You would be going for hardness with the two-part. You can also spray gelcoat, and then there're a whole bunch of other coatings that have good grip, I'm sure. I like to keep things simple, so I stick with a single part poly myself. Alan |
| I am also about to paint my boat. I am very interested in Sterling Paint. Does anyone know where I could buy it in California? Thankx |
| i paint with awl-grip 2 part, for both primer and finish, its tougher then the gel-coat, and we paint our high-end yachts with it |
| deck coating | skiffish | Materials | 35 | 01-24-2009 11:35 PM |
| Teak deck laminated with epoxy | Man Overboard | Materials | 2 | 11-05-2006 01:23 AM |
| repairing the deck with poly or epoxy? | fishweed | Fiberglass and Composite Boat Building | 5 | 09-07-2006 09:38 AM |
| Ultra Tuff Coating on Deck of Bay Boat | mike45fb | Boatbuilding | 2 | 07-28-2006 06:54 PM |
| barrier coating epoxy | fastests10 | Boatbuilding | 0 | 08-12-2002 11:01 PM |
