Old 09-10-2009, 10:16 AM
promocate promocate is offline
Rep: 30 Posts: 8
Daggerboard Material?
I've got a small sailboat (12') and the daggerboard needs to be replaced. I read through this thread, but it appears to be for much thicker boards.
what wood for daggerboard?
My current board is 4ft x 9 1/2" x 1/2".
My plan is to use marine plywood, but is there anything else that would work better?
Thanks!
Old 09-10-2009, 05:04 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
What is the current board made of? Marine ply is pretty common for thin boards
Old 09-10-2009, 05:08 PM
Rep: 30 Posts: 8
It's painted, but it looks like plywood. Just wondered if I should use something different.
Thanks!!
Old 09-10-2009, 05:22 PM
rwatson's Avatar
On a 12' foot sailboat (what model ?) you would be hard pressed to do better than marine ply, especially if you dont have a wider centreboard case.
If you wanted improved performance in a racing situation, you could do what some Mirror Sailors did (illegally), and cut some large "biscuit holes" in the board, fill with lightweight material and paint over.
The boards will break a lot sooner, and you could save that much weight by skipping breakfast.
Marine Plywood will be fine
Old 09-10-2009, 05:41 PM
Rep: 2891 Posts: 8,798
Plywood isn't my first, second or third choice for appendages, but in this case it'll be fine. To increase the strength, use two pieces of 1/4" glued together. Also cant the grain about 12 degrees to each other for maximum stiffness.
Old 09-10-2009, 07:15 PM
Rep: 30 Posts: 8
Thanks for all the feedback!!
Old 09-15-2009, 07:21 AM
CenkA CenkA is offline
Rep: 10 Posts: 11
I think,You can make composite Daggerboard !
More powerful and easy to repair.
Old 09-15-2009, 04:51 PM
rwatson's Avatar
"more powerfull" , only if you can get a wide enough board slot for the curved surface.
No harder to repair - a bit of epoxy on wood is just as easy as any composite structure
Daggerboard Adjustment Fanie Multihulls 10 05-27-2008 08:56 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
Gybing Daggerboard? Konstantin Boat Design 29 01-03-2005 04:07 PM
Daggerboard bevan Boat Design 3 03-06-2004 09:04 PM
Help!!!! ( daggerboard construction or daggerboard design ) 01639770993 Boat Design 1 12-29-2003 01:56 PM
