Old 06-18-2010, 11:07 AM
science abuse science abuse is offline
Rep: -3 Posts: 82
Dacron Sail Stitching.
What are the recomended/required/excluded types of thread when stitching 5.5oz Dacron sails?
I've got some material coming in to play with, I'm considering making a simple jib or ginny, so I can fail at something simple first. cotton based organic threads are obviously not right. I've used a braided Fluorocarbon fishing line in all of my stitching prjects (nylons, leather, cotton) up to this point, some of which have been holding heavy loads for over a decade now. Would it be safe to use that?
Thanks in advance
Eric
Old 06-18-2010, 05:17 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
I would use dacron thread.
Hoyt
Old 06-18-2010, 06:42 PM
Typhoon Typhoon is offline
Rep: 150 Posts: 125
You'll have issues with fishing line, Dacron is a fairly tough and dense sort of material, it heats the needle quite a bit, the nylon will be constantly breaking on you.
I would use a V69 waxed polyester thread with a 100 needle. Make sure to get your bobbin and top thread tensions as low as you reasonably can to reduce seam puckering.
Regards, Andrew.
Old 06-18-2010, 06:57 PM
hoytedow's Avatar
Resistor
Dacron is the trade-name for polyester, by the way.
Hoyt
Old 06-19-2010, 07:42 PM
Rep: 150 Posts: 125
Yep, it's one of them!
Finding a thread labelled polyester is usually easier, so that's why I suggested polyester.
Regards, Andrew.
Old 06-21-2010, 08:53 AM
Rep: -3 Posts: 82
Makes sense. Is there a standardized sizing for these threads? recomendations?
I should note that I'll be stitching this, as with everything, by hand, likely over the course of winter... unless you think a standard sewing machine could handle punching through a few layers of the 5oz fabric, my neighor does quilting and has the related equipment/skill.
Old 06-21-2010, 04:33 PM
hoytedow's Avatar
Resistor
http://video.google.com/videoplay?do...7107663762394#
Hoyt
Black sails - dacron? DanishBagger Materials 10 02-19-2006 04:31 PM
Black sails - dacron? DanishBagger Materials 0 02-17-2006 07:03 AM
stitching and glueing foam core Troutcatcher Fiberglass and Composite Boat Building 13 01-18-2006 10:42 AM
Dacron Sail Stretching Inquisitor Boat Design 9 12-05-2005 01:01 PM
Upside down stitching technique Inquisitor Wooden Boat Building and Restoration 5 11-11-2005 01:23 PM
