| cutting logs for strip planking I have 6 white cedar logs each about 10 inches diameter and 10 - 12 feet long. I will be building a 14 foot strip planked rowboat (glued and sheethed). My question is how and when to go about cutting up the logs (using a bandsaw mill) for strip planking? Thanks Brian |
| A band saw mill will want to be pretty robust for 10" I would be inclined to use a more savage saw to square up the logs before attempting the bandsaw. (even a small chainsaw) Preferably the logs are still green. I believe the prefered technique is to cut them to say 1.5" x 1.5" approx, and then dry them in a kiln or by air. When drying, the thicker planks are far less prone to warping, but real care in proper racking will be needed not to waste too much timber. For boat building, the "method" (quarter or back sawn) timber depends on what function the timber is serving. For planking, Quarter Sawn Boards are preferrable http://www.indeco.net.au/timber-spec...802045153.html http://books.google.com.au/books?id=...age&q=&f=false Having a chat with local mill hands is always a good bet for tips and traps |
| White cedar requires only a few short months to dry once sawn to plank thickness. It shouldn't matter how you cut the logs (i.e., plain-sawn), only that you thickness the planks for the width of the strips. You can still quarter saw the wood by deciding whether to rip some planks at right angles to the edge or the face. Use a 60-80 tooth blade when final ripping for a finish that can be glued with most adhesives. |
| Just reading Rwatson.s post, the idea of cutting to 1.5" x 1.5" is a good one, allowing choice of cutting side for quarter-sawn, though some plain-sawn 1 1/2" x wider planks can be ripped later. |
| A couple of remarks.. Band saw mils (real ones) are to cut the thick timber with least waste and best quality. Prefer air dried. Thou kiln drying dries the wood fast only time will get the shrinkage balanced with the humidity. I'm building my (strip planked) boat of 9yrs (7yrs when I started) air dried spruce dim 1 7/8" x 5". Cut them JOT to strips before using them.. |
| cut a plank...roll it 90 degrees...cut another plank...roll it 90 degrees...continue till the log is all gone... When you rip your strips outta these planks it will give you the best orientation for the grains... Cheers Tug |
| How nice to have a pile of vertical grain wood to work with. I hope the branches were knocked off long enough back to give you some clear wood. We call clean, clear, vertical grain wood butter.
__________________ If this is tourist season, why can't we shoot them? |
| now were talking my language starting from a bole and ending up a boat way to go 10" logs are a breeze tell me they have been up on stickers since the day they were dropped ends painted ? first thing you want to do is square up the log this basically knocks off most of the sap wood and also gets rid of blade eating bark your rent a sawyer will know all about trying to get the most out of a blade and your probably going to be buying one or two anyway although your really not cutting that much wood if you want to get serious go with quarter sawn in which case your sawyer might not lop off the bark first but instead quarter the logs and then turn em every cut hydraulic dogs come in handy for that as you might find out the hard way someone else nailed it when they said to cut it to the width but Ild add some for milling as your going to want to surface the slabs I buy a lot of 4 and 8/4 and its always more like 5 and 9/4 my supplier is a little generous with the wood on the one hand makes it a little of a pain in the ass if Im after an exact 3/4 or 1 3/4 but Im ok with it cause I buy mostly white oak and it tends to dry badly with a desire to season check that and I often am after a straight 1 or 2 inch finish dimension or at least to keep as much wood as possible basically leave mill wood on all the cuts you make with the band mill band saws can follow a little specially if your blade tensioner is manual instead of hydraulic either way always leave some wood for milling if your renting a saw it probably comes with an operator guy might be a hack so keep an eye on him and ask him about the tensioner lbs and if its a new blade it wants to be in the 1000 lb range or that blade will definitely be following although in cedar its probably not going to be that bad and it might be ok at anything down to about 600lb about three teeth per inch is about right for ceder I think I dont buy to much ceder and stuff makes my nose itch so I dont hang around when its getting cut much after that its all you mate enjoy the build and keep an eye on that sawyer its an interesting process to watch and your likely to be bucking wood anyway so might as well ask a few questions assuming you can hear the answers over the mill fun fun fun oh if you want to build a solar kiln they are the way to go cheap easy and works the local pet store will have moisture meters cheap and most wood can be taken down about 2% a day white oak is about 1% not sure what ceder is but Im sure you can look it up or just call one of the mills custom kiln drying is pricey and air drying takes forever on white oak its 1 year for every inch of thickness to air dry solar kiln plans are available free on line cheers B |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-05-2009 12:12 AM |
| Strip planking vs wide planking | jfblouin | Wooden Boat Building and Restoration | 26 | 08-11-2005 10:00 PM |
| plywood vs strip planking | jfblouin | Materials | 2 | 03-08-2005 03:55 PM |
| k-19 Strip Planking in progress. | bjl_sailor | Wooden Boat Building and Restoration | 12 | 01-07-2005 04:07 PM |
| Strip Planking wood | Friedrich | Materials | 9 | 12-03-2004 12:03 AM |
