Old 04-24-2005, 07:20 PM
RECONER RECONER is offline
Crapet Removal
Hey everyone, I have taken the carpet out of my bay boat and decided to paint the deck with a non-slip paint. After removing the carpet off the deck, I am left with the exposed deck. After sandind the deck, should I use a primer before rolling on the non- slip paint? After painting the non-slip on the deck should I sand between coats of non-slip?
RECONER
Old 04-26-2005, 04:51 PM
Rep: 1493 Posts: 7,447
Non slip shoud be done in one coat. I assume you have a fiberglass laminate to paint. Use the primer the paint manufacturer recomends.
Old 06-11-2005, 04:34 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,756
Small problem - presume you mean inside (OK maybe somebody COULD have carpet on the top deck but he would be a little weird I think?)
so if it's inside I presume it would be wood? (ply?) so sand and matt varnish or if you must paint - sand, prime and as many coats of non skid as you wish, but remember if you sand between coats of non skid you are removing the non skid! rather defeats the object?
Swing keel ram removal EASI54 Boat Design 0 09-05-2005 05:57 PM
Oily Bilge Water Removal LKurelja Open Discussion: All Things Boats & Boating 10 08-10-2005 08:32 AM
Mast / Spar removal - repair DNSeal Sailboats 11 07-08-2005 06:05 AM
Peel-Ply Removal bluwtrlynn Fiberglass and Composite Boat Building 5 02-21-2005 11:47 AM
fiberglass removal repmark Wooden Boat Building and Restoration 4 08-09-2003 10:57 AM
