Old 01-08-2011, 09:46 AM
Rep: 1493 Posts: 7,447
Corrosion on stainless steel
These bolts came out of a 1972 Swan. They were on the toe rail. It is mainly crevice corrosion but I think that there may be also electrolysis caused by the two SSB radios they used to have.
Corrosion on stainless steel-p1010019.jpg  Corrosion on stainless steel-p1010020.jpg
Old 01-08-2011, 10:06 AM
Rep: 670 Posts: 2,457
They were exposed to water...electrolyte. When SS is deprived of oxygen in a wet area, electrolyte, ... ......such as in a keel bolt, a rudder shaft, ss fastener in a wooden hull , a propeller shaft—it’s suffers pit corrosion, . In this pitted state the surface is no longer "passivated" ...it becomes ACTIVE and as a result is much less noble on the Galvanic Scale. This is why you don't use ss fasteners in wooden boat construction below the waterline.
Old 01-08-2011, 10:07 AM
Unless something horrible happened to the boat, toe rails are usually above the waterline.
Old 01-08-2011, 10:29 AM
Read again.....IN THE PRESENTS OF WATER.. anerobic......depassivation....Galvanicly active. WATERPROOF THE JOINT.
Old 01-08-2011, 10:37 AM
Capital letters means you are yelling at me. You did that on the previous post too. Learn some manners, and grow up boy.
Old 01-09-2011, 04:31 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
Would you have any idea about what SS quality itīs all about, Gonzo? And how far from each other were they mounted? One observation I make is that the corrosion occurrs at ~the same depth in both bolts; is there any kind of "moisture-carrying" structure at that level? You also see some free ferro-oxide near the bolt head, indicating a possible galvanic potential along the bolt length, also supporting the thought of differing oxygen concentration in the moisture at varying levels.
Old 01-09-2011, 09:47 AM
Once again...when in doubt..consult literature.
http://www.mcnallyinstitute.com/04-html/4-1.html
Old 01-09-2011, 10:33 AM
It is A4/316 stainless. They were about 5" apart. The boat had at least two SSBs installed with through-deck insulators with bare connection nuts on top. The corrosion is at the base of the toe rail, where water intrusion is most likely.
Michael: what is your disagreement with my statement that this is crevice corrosion with maybe electrolysis too?
Stainless Steel Question dreamer Sailboats 10 12-07-2009 02:40 PM
Stainless Steel Railing dannie_ga Fiberglass and Composite Boat Building 4 01-17-2008 11:11 PM
Corrosion: Immersed Steel Plate sloop2 Metal Boat Building 7 02-16-2007 05:22 AM
Stainless steel and polyester GeoffSChapman Materials 2 11-14-2006 11:19 AM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
