Old 10-10-2011, 07:31 PM
Flying Flivver's Avatar
Flying Flivver Flying Flivver is offline
Rep: 35 Posts: 37
cores
So what is commonly thought of Polypropylene Honeycomb core in boat construction?, is it hard to use?, and can it be used in a transom?
Old 10-12-2011, 12:49 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I would no use it in surfaces that are in contact with water. I have built a boat like that once, and it had continuous problems with water logging.
For a transom I would use a high density foam, or perhaps wood, if you know what you are doing.
Old 10-12-2011, 03:07 AM
Rep: 670 Posts: 2,457
I only work on boats . My observation is that On composite boats foam is the core used in primary structures. I only see Honeycombs used for interior furniture. Im looking at a door right now that is honeycomb. When I talk to builders they prefer foam because it is versatile , easy to shape, form, taper and construct with. Honeycomb is not.
Old 10-12-2011, 12:24 PM
Herman's Avatar
Resininfusion.info
the polypropylene is easy to work with. It is skinned with a layer of PP film and PET non-woven, which makes laminating it a cinch. It also conforms nicely to shape. I needed only 6 pieces of PP honeycomb, instead of 22 pieces of foam.
It is damage tolerant, due to its low shear modulus. Thus stiffness is not great. When broken, it is a pig to repair, as you cannot bond anything to the PP cell walls.
Old 10-12-2011, 03:50 PM
Rep: 35 Posts: 37
Thanks,
I want the boat to be light and long lasting so repairs are posible. High density foam it is.
Kiln Dried Treated Wood for Cores LMB Fiberglass and Composite Boat Building 10 10-29-2010 10:41 PM
Joining skins through foam cores. rwatson Fiberglass and Composite Boat Building 13 10-07-2009 08:16 PM
Cores in hull bottoms SamSam Fiberglass and Composite Boat Building 29 01-13-2007 07:06 PM
Cores?whatthehay? ron17571 Fiberglass and Composite Boat Building 1 07-22-2006 05:58 PM
Composite cores Vanbokklen Fiberglass and Composite Boat Building 11 10-22-2004 01:50 AM
