Old 02-07-2012, 11:18 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
That is why they use it in wild water canoes for a long time now (several years)....
Old 02-08-2012, 01:00 AM
Rep: 572 Posts: 646
Originally Posted by latman View Post
there must be a chemichal in the cork that inhibited the curing/bonding of my VE, all the skins were cured but barely attached to the core , I used light kevlar and carbon skins (60-160) GSM with 1 and 2mm cores and when they pulled apart you could smell the resin quite strongly.
edited to add photo
Probably phenol or a phenolic compound. It's known since ages that wood inhibits polyester resin cure and VE resin is a polyester derivate.
We made trials in the French Navy almost 30 years ago with composites wood/plywood glass fiber polyester; the problem has a solution but it's more expensive than a good epoxy resin...so it's useless.
But it's funny to see the obstinateness of using polyester on wood in a lot of so called shipyards, similar to the use in Mexico of alkidalic paint on galvanized surfaces with the inevitable result.
Yes, you're right. When using a new and unknown material tests are mandatory. I'm very skeptic about the supposed virtues of a non homogeneous material intrinsically weak and full of (natural) chemicals as core. Ok for a non structural application like seats as its great advantage is the "pliability".
Canoes can be successfully made from practically any material (in the XIXth cent. there was canoes in paper) from birch bark to carbon fiber passing by cotton cloth impregnated of oil paint so it's not a decisive proof. I would like to read real tests; chemical bonds of resins, peeling, shear with different thicknesses, fatigue with alternate cycles, curve of resistance at different temps, grip of screws, etc... All that apparently boring literature that permits an engineer to make a reasonable choice of material.
Old 02-08-2012, 07:05 AM
Herman's Avatar
Resininfusion.info
This is all I have:
http://www.corecork.amorim.com/clien.../page.asp?id=1
Old 02-08-2012, 09:04 AM
Rep: 572 Posts: 646
I have seen. Practically nothing, just a few ciphers. Having only that basis, using this material in structural applications it's hard guessing or an act of faith.
The shear is not very good and that's the main problem on composites: fracture in the core, most of the time in the interface skin/core...
You can have a relatively low shear modulus if the material has a visco-elastic behaviour.
Sure there are a lot of non structural applications, and maybe after gaining experience some structural ones. At 250 kg/m3 is not very interesting...it's a lot of weight.
Old 02-08-2012, 10:01 PM
groper groper is offline
Rep: 324 Posts: 382
This stuff is suited to applications of thin core...anything over 6mm and there's are better choices. Your people need to inderstand tho, that it behaves more like a flow mat rather than a true core like foam. Its quite unique in its practical application.
Old 02-08-2012, 10:11 PM
Rep: 572 Posts: 646
Thanks Groper for the info. In this case it has many applications.
Old 02-08-2012, 10:50 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
FORGET IT its not even worth a mention !!
I would never want to have anything to do with it for any kind of a core application not even if it wasnt used in a boat !!. Sorry !! Cork, core and fibreglass will never work ,thick or thin . Dont even go there !!
Ok What about corrigated card board !! soaked in Resin it woud be as much use !! Had one australian company trying to make panels for the side of a square water tank with Glass csm and corrigated cardboard resin soaked and csm !,was a long time ago !!. Folk lifted it onto a trailer one afternoon and 1 day later it came back in a dozen bits and the cardboard soggy and wet in a big box . Stupid people for even thinking about about trying to do something like that . !!
Making beautiful boats is a passion never a chore !
What kind of Core material should i use? VashonMike Boat Design 9 12-14-2010 05:18 PM
New 'foam' core material? Stumble Boat Design 33 05-31-2010 08:11 AM
Corecork material caneca Materials 1 04-09-2010 05:03 PM
which core material ? aldo Boat Design 8 10-26-2005 07:37 PM
Polyurethane as Core Material Victor Lemmi Materials 3 07-03-2004 01:39 AM
