Old 05-03-2004, 05:34 PM
Jeffrey Jeffrey is offline
Rep: 10 Posts: 10
Core materials
I will soon be building single and twin engine outboard tunnels hulls. The boat in question is 21 feet long 7.5 feet wide and I want it to weigh around 1200#'s. I will be subcontracting out the construction and I am looking for recommendations on the Hull, deck, transom and bulk head coring materials. All of the boats in question will be powered to run 100 to 125mph. Maybe even glass recommendations as well
Thanks
Jeff
Old 09-17-2004, 07:11 AM
Henry Nicholson
Materials Sales
Jeffrey,
The massive slamming loads that a boat like this would recieve means that you need a core with an immense amount of toughness and elongation, Core-Cell is a market leader for these type of applications and is commonly used in powerboats and racing yachts where other PVC foams tend to break down or suffer from Core shear. Plywood or a 200kg foam would be required in the transom to support the engines, though make sure ply is well sealed before use to stop any moisture ingress.
Core cell can be used with epoxy or polyester and can be 'thermoformed' to hull s which is handy
Hope thiis is useful
Henry Nicholson
Henry
Old 10-16-2004, 10:38 PM
Keith Burnham
transom
I am look for a material that they us for a transom that has on wood in it compoust.
Old 10-17-2004, 05:06 PM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
Think outside the circle.
A sandwich concept is great. But if you are aiming for the higher end of the performance scale. Move towards carbon for your skins. The increased stiffness would help transfer the loads into your bulkhead. Thus stressing your core to a lesser degree.
Long-grain and endgrain balsa has high shear properities.
Buckle
Buckle
(Composite Engineer)
Old 10-25-2004, 10:14 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
For boats running 100-125 mph, I would certainly advise to look for a technician with at least the experience in that business. Or at least unveil some general drawings, so people can make some more specific recommendations.
To be more correct about Core-Cell:
This is not a PVC foam, but a SAN foam. It characteristics hold middle between cross linked (more brittle) and lineair (more ductile) PVC foams.
Nowadays there are more types of Core-Cell, with higher compression strength, higher stiffness, and temperature. Please check out their website and take a look at the datasheets for more info.
You can also contact SP North America, and see what they recommend.
Structural Foam mistysea Materials 6 05-10-2010 09:58 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Use of wood as core in polyester jfblouin Materials 24 02-20-2005 09:38 AM
A new type of core? Fred Boyle Materials 7 01-06-2005 11:25 AM
core materials gasdok007 Boat Design 0 11-11-2004 10:09 PM
