Old 02-10-2006, 04:19 AM
CapKos CapKos is offline
Rep: 15 Posts: 47
Copper Cloth
In the past ships have used copper sheets under the waterline, and some classical yachts still have. My question is: is it possible to replace the glass cloth of wood-epoxy boat at list under water line with very thin copper sheet? This could be stronger, and probably cheaper on long run since no antifouling will be used.
All the best,
CapKos
Old 07-16-2007, 01:30 PM
Rep: 472 Posts: 1,391
I would rather mix copper powder into epoxy paint. You might have copper separating from Epoxy becuase it creates copper sulfate layer becuase of some moisture that might get through. Epoxy is not 100% moisture resitant even thought it is close. I saw company one time offer at show system to coat bottoms in copper flakes. It was expensive and I dont thing it 100 effective becuase other marine life will get some foothold. You still have to clean it or coat it with biocide.
Old 07-16-2007, 02:09 PM
nero nero is offline
Rep: 112 Posts: 624
It is not copper. It is cupro-nickel that is used for bottom coating. 90:10 80:20 and 70:30. The more nickel in the alloy:the more expensive it is.
Copper by itself is not that effective.
Cloth over cloth, no mat Koz Materials 13 01-30-2006 06:18 PM
Copper Rivets (1969) enahsx Wooden Boat Building and Restoration 1 11-20-2005 09:38 PM
Copper Bottoms Capthookcc Wooden Boat Building and Restoration 18 03-14-2005 07:18 PM
Plumbing Copper Pine Mr. LowTech Materials 4 11-05-2004 12:59 AM
Copper/Nickle Boat Hulls brian eiland Materials 0 07-05-2004 12:32 PM
