Old 04-01-2008, 09:22 AM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
compound curve windows?
can you bend some kinds of "plastic" windows in two directions, with heat?
Old 04-01-2008, 10:18 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
Yes. It is an expensive process to have done. I assume because a mold is required (made perhaps from wood, into which the heated plexi settles or is driven by air. I'm sure someone who knew the process could do it at home, but I don't know where one could learn the details besides experimenting.
Alan
Old 04-01-2008, 11:43 AM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 253 Posts: 526
I found a lot of info online a few months ago - Google "heatforming acrylic" or similar terms. I'm sure anyone who could create a boat requiring compound curves could master the process of heat-forming the plastic sheets. It seemed kind of low-tech.
Old 04-01-2008, 10:19 PM
nero nero is offline
Rep: 112 Posts: 624
I found a .pdf a few months ago. Compound curves can be done cheaply and by do-it-yourself.
The technique of interest is drape forming. Many things can work for the form. Wood, Fiberglass, Aluminum, etc. One of the tricks to give a smooth surface is laying 3 mm felt over the form.
Not sure I am going to try this. A flush curved window would be at greater risk to fender lines and other objects that would leave scratches.
Old 04-01-2008, 10:27 PM
Pompuous Pangolin
Rep: 43 Posts: 624
yes but driving a kite one needs good view.. would you send me the pdf?
Bedding Compound? flydog Boat Design 7 05-15-2010 08:36 PM
Bedding/sealing compound help skiffbuilder Wooden Boat Building and Restoration 2 03-10-2006 09:35 AM
Touch'n'Foam as a fairing compound...? Stephen Ditmore Materials 0 01-09-2006 10:39 PM
fairing compound over gelcoat ? newo eloc Fiberglass and Composite Boat Building 3 07-08-2005 09:18 PM
fairing compound HWL Fiberglass and Composite Boat Building 18 03-19-2005 02:05 AM
