Old 11-25-2006, 09:47 AM
ComputerJoe ComputerJoe is offline
Rep: 10 Posts: 4
Composite Wood Deck Expirences
I am in the process of laying composite wood deck over aluminum frames. The decking itself is structural so I found a residential decking material (Timber Tek) that was rated to span 24" centers. My expirence has proven this material to have good slip resistant properties when wet. As there is no sub-deck and the material is tongue and groove with weep holes I am cauking the joints with silicon. Small leaks are acceptable as a weather deck it only covers mechanical spaces. I doubt that I am the first to try this material and hope to get comments on it's use.
Cored composite with wood inner sheathing Man Overboard Fiberglass and Composite Boat Building 10 01-31-2007 05:34 AM
Composite Steel/Wood Space frame analysis lawrencepeckham Software 21 11-13-2006 05:00 AM
composite wood aluminium bertho Wooden Boat Building and Restoration 1 08-16-2006 04:28 AM
Wood Deck Help meko45 Wooden Boat Building and Restoration 0 04-13-2006 08:41 AM
Wood Cold Molded Epoxy/Composite Builders winap Wooden Boat Building and Restoration 6 07-23-2004 08:02 AM
