| Composite Panels As far as I'm aware, ATL are the only major suppliers of 'faced' composite panels in Australia (Duflex foam and balsa) Is anyone aware of any others?
| Will, Coreman composites used to have a big laminating table, think it all got "too" hard, theres a firm in towoomba that does big panels for trucks etc & took part in a Kellsal project & I got 2 tables 1.8 x 3.6 & one thats 7.2 x 1.8, we can "sister" them up for 7.2 x 3.6 etc or you can get glass-melamine/whatever & make your own- they do glass in 3.1 x 5.? sizes but exxy to transport & support, I think you in Tas. mabe talk to Angelo P at some place south of Hobart- he could maybe set you up with some panel manufacture. All the best from Jeff. |
| Hey Will, Boat Craft Pacific based in Queensland do a product called Neadaplast (spelling) http://www.boatcraft.com.au/composites.html There site is down at the moment. But I have used it throughout my last boat. Its a honeycomb plastic core covered with either ply or fibreglass. Or a mixture of the 2 ply and ply - glass and ply - ply and nothing etc - comes in various thickness from 8mm up to 32mm - I have some 32mm for table tops - real light - a bit like ATLs featherlight but with a plastic core instead of a paper one Cheers John http://www.johnwatson.net.au |
| More on DuFlex Also will I am using DuFlex to build a new 17.5m catamaran we have been into it for 3 weeks or so - the wait for panels is now out to around 12 weeks - everyone seems to be into it big time. Cheers John http://www.johnwatson.net.au |
| Hi John Thanks - yes I found the Boat Craft stuff - they call them Coretech panels. As you say this covers a range of panels that includes Nidaplast honeycomb. I've asked them for more information, so look fwd to getting that. How does it compare in terms of cost to comparable Duflex panels? It's structural properties are quite different to both foam and balsa, having similar compressive but lower shear strength. Interesting web site by the way.... Have you got pics of the new boat? Jeff - thanks - I'm trying to avoid having to "make" the panels if possible, though it does have the advantage of being able to make them almost any size....
| Hey Will, Cost - its a few years back now and seem to think I was paying around $250 for a 20mm thick panel covered with gaboon ply either side (Coretech) - I used these for the bridgedeck - The interior was mainly costructed of 13mm Nidaplast for the none structural stuff - can't remember the cost about $180 a sheet then - but was a while ago. New boat yes I have a few photos. We have the side of one hull completely planked and part of the other side. I expect to fully planked with just the chamfer panel left to do after 10th Dec. Think I have uploaded 2 pics - not that good will get some better ones if you are interested Cheers John |
| well looks like only one picture |
| Always interested!
| PM me your e-mail and I'll send you some pics John |
| Hunt around your local builders and find somebody who can bag up panels to your own specs on a large table. ATL's product is good, but they are limited to 8x4's and are expensive. Nidacore imo is a material best left to non structural applications eg furniture, non structural shelves/locker bulkheads etc. Has a very low shear strengh compared to foams of same weight. Under no circumstances would I use this still in a structural application. |
| Capt'jsws lead time indicated of 12 weeks is a fair while, in that time a table could be easily set up- table laminating is as nice as it gets & you can incorperate tabbing rebates to the panels edges to ease fairing & after joining you gotta handle big sheets anyway. Some of the Duflex kits look like they go together pretty quick but I spose if you gotta wait for the material that might even that out a bit although the computer cut thing sounds pretty cool & the ATL panels look to be of consistant quality from what I've seen. All the best from Jeff. |
| I'd agree that the Nidaplast cores in the Coretech panels are inappropriate for most structural applications - though I note that that isn't how they're marketed ... And I have managed to locate a company that is laminating panels for their own use - hopefully they'll be prepared to supply as well. I think that the biggest selling point for the Duflex panels is that they are a known quantity - well known, reliable and extensively throughout the industry. Cost and size limitations are indeed their most obvious drawbacks... |
| " Nidacore imo is a material best left to non structural applications eg furniture, non structural shelves/locker bulkheads etc. Has a very low shear strengh compared to foams of same weight. Under no circumstances would I use this still in a structural application." We have used the 2 inch as cabin tops on 40ft replacement job. 12ft x 14ft . Seemed fine with a dozen guests stomping on it , but under water would be a different story. FF |
| Nidacore is fine for structural applications if you take into account the lower shear strength. This usually means the panel has to be a bit thicker then if it where built from PVC. This makes the panel stiffer and stronger and you can usually use lighter skins (unless you are ruled by a std with minimum skin thickness) But its cheaper and about the same density as 80kg PVC. Many boats have been built from it 100% overseas, very big boats as well. I think the main problem is that some people don't vacuum bag the skins which means the skins don't bed into the Nidacore scrim very well. If its vacuumed bagged correctly they are very tough and stiff. Peter |
| Converting Plywood Design to Composite Panels | James Mills | Boat Design | 10 | 09-20-2007 06:37 PM |
| Panels | Drip | Fiberglass and Composite Boat Building | 3 | 06-27-2006 09:48 PM |
| Solar panels | gonzo | Electrical Systems | 3 | 01-10-2006 07:19 PM |
| Unsightly Panels | aitchem | Metal Boat Building | 3 | 12-01-2005 07:05 AM |
| Solar Panels | sunshinesolar | Boat Design | 0 | 08-27-2004 02:49 PM |
