| closing up inboard holes im converting to outboards and cut out the shaft logs.what im left with is a 10''x15'' hole.the material is 3/4 of an inch thick.how should i repair this.i was going to use 3 layers inside and fair the depth with kitty hair then grind and use 3 layers on the outside.the patch material is combo cloth (woven roving with matt stitched to it.does this sound ok.and how far from the hole do i have to start the repair |
| I would probably use some sort of high-density insert (foam or plywood) with multiple layers of biaxial glass inside and out, with epoxy. We have everything you would need at boatbuildercentral.com. If you send us pictures, I can have our boat designer look at it and recommend a lamination schedule. We do this for free when someone buys the supplies from us. Joel |
| Inboard to Outboard conversion | Crishinor | Propulsion | 4 | 06-15-2005 12:05 AM |
| Inboard to outboard conversion, need help with details. | bradmc | Boat Design | 1 | 05-11-2005 11:10 PM |
| outboard as in inboard? | tryin to float | Boatbuilding | 17 | 08-12-2004 11:04 AM |
| Composite Question, filling transom holes | foca | Powerboats | 5 | 07-10-2004 12:46 AM |
| An alternative to limber holes? | jonathank | Metal Boat Building | 0 | 07-08-2004 09:05 AM |
