Old 04-17-2006, 03:08 PM
man5 man5 is offline
Rep: 11 Posts: 37
Clark craft
Anybody ever use this company before? Its closer to home so I figured Id give them a look see. 1:1 Epoxy seems good priced and probably easier to measure out. thanks http://www.clarkcraft.com/suppliesli...b9d621af6db281
Old 04-17-2006, 03:47 PM
JEM JEM is offline
Rep: 38 Posts: 291
Using an epoxy that has no amines would be a welcomed change for many.
Matt - JEM Watercraft
Old 04-18-2006, 11:56 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
I've used them and the product is nice to work with. A bit spendier than I like so I switched to Progressive (2:1). I did like it's tolerance for (slightly) off ratio mixing and it had a medium kick time...decent in warmer weather and good down to about 50 degrees. A good epoxy to learn with.
Steve
Old 04-18-2006, 08:14 PM
Rep: 11 Posts: 37
lewisboats- you must be buying in bulk. Cheapest I could find at progressive is $75.00 per 1.5 gallon($50.00 per gallon). I was looking at buying 5 gallon plus and clarkcraft is $216.00 per 5 gallon. ($43.20 a gallon). I must be missing something though because I get lost on progressives site. Thanks.
Old 04-18-2006, 10:15 PM
lewisboats's Avatar
Obsessed Member
Probably not (missing something)...I haven't used Clark Craft in about 5 years. When I did it was something like $10 more expensive per gallon than Progressive. I haven't checked the prices lately. Maybe I should have as I just bought 1.5 gals and could have saved myself some $$$
Steve
Old 04-20-2006, 09:02 AM
lewisboats's Avatar
Obsessed Member
I checked and they still are about $10 more a gallon...Don't need and couldn't afford to get 5 gals at a shot. Still using up the last purchase from about 2 years ago.
Steve
Old 04-28-2006, 08:57 AM
jimslade jimslade is offline
Rep: 14 Posts: 304
I like their 1-1 epoxy resin. worked well for me.
Me and my Sleek Craft Sully Boatbuilding 2 05-28-2005 03:01 AM
Clipper Craft Terry Powerboats 0 03-01-2004 06:47 PM
Clark Craft Plans and Patterns Hynek Janda Boatbuilding 1 01-27-2004 04:50 AM
Clark Mills Biography edneu Boat Design 2 10-24-2003 10:59 PM
Strand-Craft Guest Marketplace 0 06-29-2003 02:40 AM
