| Ciba-Geigy epoxy Does anyone have any experience or details on Ciba- Geigy epoxy? My local fiberglass cloth supplier wants me to get epoxy from them as well. They couldn't really give me many details other than to say it was a one to one mix. Just wondering if anyone knew how it performed. I'd need a really good reason to switch from what i know works well. Rob |
| Epoxy I like system 3. The gel magic I tested at FAU was found to be strongest in interlaminate sheer, and high velosity impact. We tested against several over the counter epoxies. Ray |
| Details on Ciba-Geigy epoxy Quote:
| I want to know more about Ciba-Geigy epoxy,technically and its application. |
At one to one it definitely will have different properties. This guy has a lot of good info. http://www.epoxyproducts.com/ |
| I know a man in Oslo, Norway, built a could moulded sailboat with epoxy from Ciba maybe 20n years ago. The boat is still sailing. I think the quality is good enough. Usability and additives (and cost, of course) seem to be important. |
| Thanks for the feedback! |
| I've used it and didn't like it much. The viscosity is very high which makes it a hard job to wet the cloth.
__________________ Gonzo |
| I can appreciate that. Can you reccommend any "quick cure" epoxies (60 minutes or less) that would be good for assembling parts? I don't want to skimp on construction, but it would be nice not having to wait overnight for moving on to the next step. Rob |
| West system 105 with 205 hardner @ 85deg F. (A 1mm film) Do not leave "en masse" at that temp. ( in pot) or you will lose it in 10 minutes.Epoxy is VERY temperature sensitive. If you have difficulty warming your shop to this temp. make a hot box. |
| I'm going to have to play with the fast hardner some more. I've been using West for everything. It just seems that when I try to do a faster set, it still takes a good 12-14 hours to get to the point where it isn't to tacky to handle. I guess I will have to push the heating process a little more. In the past, I have taken some 30 minute model airplane epoxy, warmed the bottles in a water bath, and had it set in about two minutes. I think I need to set aside an evening for expirmenting instead of building. Thanks, Rob |
| I thought Ciba-geigy had switched to the Huntsman brand name globally.Perhaps this impression is wrong but I think if you Google Huntsman+epoxy you ought to find many different epoxies,among these there ought to be something suitable. |
| When to Epoxy | JosephKeel | Wooden Boat Building and Restoration | 8 | 03-03-2007 11:30 PM |
| epoxy primer sprayed on green epoxy laminate? | bntii | Boatbuilding | 12 | 10-16-2006 06:41 AM |
| Need Epoxy Help | Valkyrie | Materials | 2 | 11-27-2005 12:56 PM |
| Epoxy......how much i need? | {NW}BKUSA | Wooden Boat Building and Restoration | 7 | 01-21-2005 05:14 AM |
| how much epoxy | Boatbuilding | 2 | 07-01-2002 05:39 PM | |
