Old 06-23-2006, 03:13 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
chopping and joining windsurf mast?
should I use an inside wood dowel or outside glass mat/epoxy sheathing for the join? the purpose is to have a collapsable mast.
Old 06-23-2006, 11:55 PM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Sigurd, have a look at a standard 2 piece windsurfing mast to see how the join is made. The lower section has a thickened and reduced section at the top which is part of the structure, not added later. The top section of the mast slides over this reduced section and makes a very neat connection to the lower half. The windsurfing sail exerts pressure pushing the two halves together.
I dont know if you can manufacture a satisfactory join yourself. Better to buy a 2 piece mast.
Kayak hull joining question Thin water Fiberglass and Composite Boat Building 12 07-06-2006 12:43 PM
Any tecnical problems joining m/s with cor-ten ? globaldude Metal Boat Building 2 04-26-2006 06:28 AM
Joining longitudinals to the frames KajWestergard Metal Boat Building 40 02-14-2006 04:03 PM
Joining longitudinals to the frames KajWestergard Boat Design 0 01-24-2006 02:52 PM
Joining points in Prosurf Willallison Software 2 09-09-2002 06:49 PM
