  #76
Old 04-20-2011, 11:17 PM
vkozar vkozar is offline
Rep: 10 Posts: 9
Hi guys.
I am taking a project boat. It is 1979 49' Marine Trader Pilothouse.
Boat need completely new decks. What thickness of Coosa 26 should I use?
1/2" or 3/4" ? If anybody have experienced with it? Is it a good idea to use this material?
Ocean Limo
  #77
Old 04-21-2011, 10:17 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
For adhession between core and glass Balsa wins hands down . Have you ever tried to rip glass of a balsa core ?? On the other hand foam has this thing of beng able to PEEL off the glass and thats scary !!
Peel is the test foam falls down on badly . low density foams almost come apart if you simply drop the panel on the floor . Even high (h80) density peels real easy as well so from the peel side of the coin look again folks . Always used H80 foam on decks where theres high traffic and h200 under pads for bolt throughs like winchs etc etc . Make the pads big to distribute load . and add layers in steps and feather them to well .
Making beautiful boats is a passion never a chore !
  #78
Old 04-21-2011, 11:05 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
Do you know for sure that it is a cored deck? the reason i ask is that a friend has a Marine Trader 36 and everything above the fiberglass hull is glass over plywood. I have no idea if that is typical.
Steve.
core-cell for deck Bentwood Fiberglass and Composite Boat Building 2 05-13-2008 11:29 AM
Foam Core - Deck, Cabin, Bulkheads SeaJay Fiberglass and Composite Boat Building 18 08-28-2007 09:15 PM
Optimizing core/skin thicknesses......for a deck Roly Fiberglass and Composite Boat Building 6 12-08-2006 01:39 PM
core-cell deck fabrication dolsen Boat Design 2 06-20-2006 06:50 AM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 06:20 PM
