| Choice of fiberglass for strip planking hull I'm in process to put fiberglass (with Epoxy) on a new strip planking hull. I'm looking for a layer of 17 oz (45-45) biaxe plus two 18 oz (0-90) Biaxe Or two layers of 17 oz (45-45) biaxe plus one 18 oz (0-90) biaxe Or one layer of 17 oz (45-45) biaxe plus one layer of 1808 (18 oz of 0-90 biaxe with 0.75 oz stiched mat) (I already have this stock). What is yours suggestions or comments ? Thanks
__________________ Jean-Francois Blouin PS Sorry for my not so good english |
| Hard to tell without knowing the boat length, use of the boat, frame spacing and thickness of the strips. If you use epoxy you don't need the mat. It's only required with polyester to make the plies stick to each other. Although it makes sense to use some mat as the outer layer to reduce print through. If you don't want to apply so many plies maybe find some quadraxial glass. It has fibres running in the 0, 90, +45 and -45 degree direction. |
| as I understand it ... and if this is sheathed strip construction, the best choice is uni glass or uni carbon running across the strips at 90 degrees. Any other sheathing is for abrassion resistance, which is best to run with the planking. |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
| Fiberglass Hull Liner Question | Seadog | Fiberglass and Composite Boat Building | 7 | 08-14-2005 07:42 PM |
