#31
If you monitor isnt correctly adjusted, the colours themselves are off. There must be a better way - something commercial like they use at Paint Shops. |
#32
| We use a computer with a color eye similar to a paint store, it needs to be calibrated for the exact pigments being used, plus be recalibrated for each new batch of pigment. There are people that can do it very well by eye, but its almost a lost art. |
#33
However, if you have a match, check and see how your three main pigments compare to the ones on screen and adjust the color intensity of your pigment colors to match. Mix them up and you will have a close to perfect match. If a bit off, adjust the color and read the sentence in the quote above. Unfortunately, I write this post from my house computer and the applets are not on my bookmarks here, but there is another link we use together with this basic applet mixer that actually shows how colors changes with different colours added and this let you know what to add to get a color darker/lighter or to fade it a bit.... As said, we do repairs of gelcoats quite successfully regularly using this method with the limited amount of color pigments we have. Remember, necessity is the mother of all invention....
__________________ Fair Winds Wynand Nortje There are no problems, only solutions - John Lennon; 1940 - 1980 |
| White gelcoat yellowing problem ? | pescaloco | Fiberglass and Composite Boat Building | 6 | 11-09-2009 10:25 AM |
| Deck Removal | aboyd | Boatbuilding | 18 | 08-18-2009 05:45 PM |
| PreKote From Pantheon CHemical; Anyone tried it yet? | Jimbo1490 | Open Discussion | 13 | 09-15-2008 10:39 PM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 08:53 PM |
| Missing the "chemical key" window. | Roly | Fiberglass and Composite Boat Building | 3 | 06-14-2006 11:33 AM |
