__________________ Regards Fanie |
| I looked at your magazine plans. Taping the seams will help keep it waterproof. A little bit of extra work that will insure a better product is to make a putty by adding baby powder to the resin until it thickens into a clay like consistancy and packing it into the inside corners. this is called a fillet and the purpose here is to gently round the the inside corners. Fiberglass cloth, matte, or tape doesn't like sharp crisp edges. If you do this after the first coat of resin and then cover with tape for the next coat it will be a little nicer. A couple layers of tape and you're starting to talk cadillac here.
__________________ If this is tourist season, why can't we shoot them? |
| Skip the waterproofing and build a solid wood tub? Build it up with planks and hoops like a barrel. Use 5/4 x 6" redwood or cedar deck boards. Buy 8' boards so you get three pieces out of each board. Will take some skills learned and time but more fun and nicer than the ply box with resin splashed inside.. Like this just smaller: Or just buy something like this?: ![]() Will cost less than the epoxy needed for the ply tub.. |
| I looked around for some wine barrels but they were ridiculously expensive that plastic tub still looks a bit big i only need something about 1.5 feet wide 2 to 3 feet long and 2 to 3 feet tall how come you dont need to waterproof the plank bathtub? won't it rot? btw i found this resin http://www.westmarine.com/webapp/wcs...&ci_sku=232527 the filler blend's $20 is that acceptable? |
| Dr Rot has the goop for which you're searching. Google it - you can order it shipped directly to your mother earth project center. |
| Casting a keel. | LP | Sailboats | 9 | 01-18-2008 05:20 PM |
| Casting Platform | duckdog | Boat Design | 0 | 12-12-2007 09:56 AM |
| Laminating 50%Glass/50%Aramid Cloth with Polyester Resin on a Foam Core | Paulo | Fiberglass and Composite Boat Building | 11 | 04-24-2007 07:54 AM |
| Casting lead | vabob7 | Boat Design | 0 | 03-08-2005 10:32 PM |
| Epoxy Laminating Resin | JEM | Fiberglass and Composite Boat Building | 0 | 11-17-2004 08:45 AM |
