Old 05-24-2004, 11:02 PM
Jim Kartz Jim Kartz is offline
Rep: 10 Posts: 8
carvel bottom
I have just bought a 15' century resorter with 192 hours on meter,bottom condition is good. Has anyone used Dr. rots cpes,poly (3m4200)caulk,elaxstuff120 system of coating the bottom? Any opinions will help.any other sugestions? I dont want to soak bottom. thank you Jim
Old 05-25-2004, 04:45 AM
Rep: 2891 Posts: 8,789
If the bottom is in good condition don't fix what ain't broke.
That said, this is a trailer boat and the only type of boat I'd recommend a bottom coating. The boat will never be in long enough to make a coating an issue. The issue will arise if it doesn't get the care it (the coating) needs.
That said, there is less care required in traditional construction without coatings then with, by coatings I'm talking about stuff other then paint/varnish.
If you have rot issues, then address them properly. There is no magic goo in a can that will turn dead wood into less dead wood, regardless of what the advertisers and can label says.
If the boat leaks, find out why and address the problem, don't smear goo all over or pack mystery mud in the seams. It will do a lot more harm then good.
The products you wrote about have their place, but a lot of folks try to stretch the envelope in their application and use, only to find a few years down the road a bigger and more damaging result of their craftiness.
Old 05-26-2004, 11:02 PM
Rep: 10 Posts: 8
When I said bottom was in good condion I ment I found no soft spots. Just read Danenburg,enlighting! this type of bottom should not be caulk. Peices of cotton sticking out of seams,planks have not forced them selves away from frames yet bottom transome frame has crack and will be replaced starboard side only cracked.
Old 05-27-2004, 01:47 AM
Misogynist Misogynist is offline
Rep: 10 Posts: 30
Nice quote PAR.... There is always someone to sell "snake oil"... or "magic dust" that will repair rotted wood.....
Need help on designing stepped forward-vented bottom hulls with staggered strakes Trimix Education 0 09-16-2004 04:13 PM
Need help on designing stepped forward-vented bottom hulls with staggered strakes Trimix Boat Design 0 09-15-2004 01:15 PM
Saggy Bottom reen8888 Sailboats 1 04-22-2004 10:27 PM
Plywood bottom attachment Tim Dykes Wooden Boat Building and Restoration 3 04-17-2003 12:08 PM
