Old 05-23-2009, 06:21 PM
SeaJay SeaJay is offline
Rep: 10 Posts: 79
Carbon rudder posts
Does anyone know if a carbon rudder stock can be used directly against an UHMWPE bearing, or should a stainless sleeve be attached to the stock? I thought I read somewhere that the SS needed to be used as a wearing surface, but that may have been in conjunction with roller bearings. The SS seems somewhat problematic as I suspect there may be some electrolysis occuring between it and the carbon. Thoughts?
Old 05-23-2009, 08:21 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
One thought was : use more acro´s and get more replies!!! Naturally YWNUWIM?
at the end..............
Fortior est qui se quam qui fortissima vincit Moenia.
Old 05-23-2009, 10:44 PM
nero nero is offline
Rep: 112 Posts: 623
You will need a sleeve for a wearing surface. Or you can machine the bearing on to the stock and use a bearing surface in the rudder tube.
Or maybe someone can say if UHMW-PE can rub against UHMW-PE and survive.
Old 05-23-2009, 10:59 PM
mark775 mark775 is offline
Rep: 141 Posts: 383
And no, UHMW cannot ride well against UHMW.
Old 05-24-2009, 06:09 PM
Rep: 10 Posts: 79
Mark, Nero, Thanks.
Apex,
Ultra High Molecular Weight Polyetheylene
Old 05-25-2009, 12:27 PM
Eric Sponberg's Avatar
Rep: 245 Posts: 418
In my carbon fiber rudder designs, I always specify stainless steel sleeves. This is because, in a composite laminate, the determining factor, really, is the resin, and epoxy resins wear down really fast. You have to have a hard wearing surface. I have had on occasion specified other plastice bearing surfaces to be bonded to the carbon fiber part--the point is, you need a bearing surface on the stock to take the bearing pressure and wear. Do not let the bearing ride directly against the carbon fiber stock.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 05-25-2009, 03:29 PM
apex1's Avatar
Steamer
SeaJay
thanks, I know that as "High modulus PE"
Richard
Old 05-25-2009, 04:19 PM
Rep: 10 Posts: 79
Thanks Eric,
Actually, I thought it was one of your articles that had mentioned the SS surface but I couldn't find it again (or was too lazy to continue my search!). What is the best method to attach the SS to the carbon stock? Set screws don't seem like a good idea, but does epoxy or similar (EasiChock http://www.tigerpropellers.com/orca_grease.htm ) provide enough adhearance between the SS and carbon? I saw a couple of rudders where it looked like this was the method used so I guess this is the way it is done.
Regards,
Doug
Old 05-26-2009, 09:50 AM
Rep: 245 Posts: 418
SeaJay,
Yes, epoxy is fine for bonding. Sand the mating surfaces first to a good roughness with coarse grit sandpaper before gluing.
The article you probably saw was "Keels and Rudders: Engineering and Construction" in Professional Boatbuilder #96, Aug/Sep 2005, page72. Here is a link to the on-line digital version: http://www.proboat-digital.com/proboat/200508/
Eric
Eric W. Sponberg
Naval Architect
Old 05-26-2009, 07:49 PM
Rep: 10 Posts: 79
Thanks Eric. I was looking in that particular article but missed the notation in the drawings. That was exactly what I was looking for. SS it is!
Doug
Rudder Post in Carbon or Kevlar nero Multihulls 11 03-10-2009 07:40 AM
rudder profile and carbon stock andrewfennell Boat Design 3 12-31-2007 11:22 AM
carbon fibre rudder shafts jamesa Multihulls 14 04-21-2007 03:09 PM
Carbon layup for a rudder and daggerboard usa1154 Fiberglass and Composite Boat Building 1 01-25-2006 01:14 AM
