Old 03-15-2003, 10:21 PM
Ssharpsjc Ssharpsjc is offline
Rep: 10 Posts: 5
Carbon and corrosion
I am looking for advice on insultating metal fasteners on carbon masts and carbon sails. The current method requires the use of titanium materials which are difficult to come by. Are there any suggestions on how I might adequately insulate stainless so that it can be used?
Old 03-17-2003, 01:35 AM
Rep: 1397 Posts: 7,215
I don't have first hand experience, but some people have been succesful with plastic washers and sleeves.
Old 03-20-2003, 06:00 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Just out of interest .. where did you get the info about needing to use Titanium?
Paul
Old 03-23-2003, 01:17 PM
Rep: 10 Posts: 5
Since posting this question about carbon and stainless I have phoned several designers and suppliers of carbon masts. None have any experience that indicates a direct corrosion problem. Most uses of titanium are for lightness not corrosion. In fact there are several hundred carbon masts with stainless fasteners on the water and many are over 10 years old and have considereable sailing time on them. The initial concern seems to be fantasy from someone I should have known not to trust.
Old 07-05-2003, 04:49 PM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,267
checking aluminium, stainless steel, carbon on weight, bending and price. titanium claims to be fair priced (how fair?) be lighter and stronger than alu. just getting into reading how to weld it at materialsworld anyone here with experience?
Old 07-08-2003, 09:24 AM
Morgig Morgig is offline
Rep: 10 Posts: 50
Although not directly related, I have heard of problems associated with carbon rudder stocks and alloy bearing housings. It would therefore make sense to give some consideration to water trapment when using any fittings less nobel than carbon.
Corrosion between Al and carbon grob Materials 11 02-18-2005 12:39 PM
