Old 07-17-2006, 11:33 PM
willfishforbeer willfishforbeer is offline
Rep: 10 Posts: 15
Cant use epoxy resin with fiberglass mat?
I've heard you cant use fiberglass mat with epoxy resins. Is this true?
Old 07-18-2006, 12:18 AM
JC47 JC47 is offline
Rep: 10 Posts: 17
You will need to purchase stitched mat to work with epoxy. I use Vectorply products currently doing layup with with quadaxil product with the mat stitched to it. Regular mat has a binder in it that the polyester resin dissolves when it is whetted out, that is incompatible with epoxy. Good Luck
JC47
Old 07-18-2006, 01:28 PM
Rep: 10 Posts: 15
Thanks alot!
Old 07-18-2006, 06:52 PM
Rep: 95 Posts: 462
there is a chop strand mat for epoxy you can also get chop strand carbon also it has a different binder than the mat that you use with polyester cost alot more
Old 07-18-2006, 08:50 PM
FastLearner? FastLearner? is offline
Rep: 10 Posts: 13
Where would one find these products? Thanks.
Old 07-18-2006, 10:16 PM
Rep: 95 Posts: 462
most fiberglass dealer will have it or order it for you
Old 07-19-2006, 12:01 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
We test all the mat we order for its compatibility with our epoxies. Our 1708 for example works with any epoxy. Most of the time, you do not need mat when working with epoxy. The mat is there mainly to provide a decent bond between two layers of directional of woven cloth. With epoxy there is no bonding problem, so you just use the woven or direction right over top the previous layer. The mat will just give you some bulk – which is sometime helpful but most of the time just results in more weight for the same strength.
Joel
Boatbuildercentral.com
www.boatbuildercentral.com
Old 07-23-2006, 05:09 PM
Doug Lord
Epoxy compatible mat
Here is another source for epoxy compatible mat:
Fiberglass Mat
Address:http://www.shopmaninc.com/mat.html Changed:2:35 PM on Monday, July 4, 2005
Old 10-11-2006, 11:36 AM
l_boyle l_boyle is offline
ol' can of sardines
Rep: -5 Posts: 41
for epoxy is too expensive to use... it'll soak up alot of epoxy before you can get a smooth coat... I rather use layers of cloth than using a single mat
Old 10-11-2006, 04:20 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
If you have to use mat for some reason and want to keep it light, wet it , put it in between 2 sheets of plastic and squeeze the extra out before you lay up, works on small parts. works on woven 2.
Old 10-11-2006, 07:04 PM
catmando2's Avatar
catmando2 catmando2 is offline
Malaysia bound....soon
Rep: 38 Posts: 167
Whats chopped strand mat and woven rovings?????
Only joking.
Dave
Old 10-20-2006, 02:19 PM
sbklf sbklf is offline
Rep: 10 Posts: 43
Joel
How do you test it for compatibility?
Old 10-20-2006, 02:30 PM
SHINE
Rep: 50 Posts: 282
Its stitched together, which normally would mean its fine for epoxy. But we want to be sure because we deal almost 100% in epoxy, so I actually take a piece and laminate it to wood.
If it had a lot of binder in it, the glass would look milky. If it goes pretty clear its fine.
Wetting out biax/mat or roving/mat is not as easy with epoxy as it is with polyester. Most epoxies, even "laminating" epoxies are not as thin. In many cases, I get better laminations easier from 2 layers of straight 12 oz. biax (no mat) than 1 layer of 1708
Old 10-20-2006, 02:35 PM
SHINE
Rep: 50 Posts: 282
fiberglass chopped strand mat for frp yacht ssgfiberglass Marketplace 12 05-03-2006 08:03 PM
Epoxy Laminating Resin JEM Fiberglass and Composite Boat Building 0 11-17-2004 09:45 AM
Epoxy Resin eurotk1 Fiberglass and Composite Boat Building 6 08-27-2004 04:50 PM
epoxy or polyester resin gbaaron Powerboats 2 06-20-2004 09:52 PM
epoxy resin? jstephen Wooden Boat Building and Restoration 5 02-23-2004 08:32 PM
