| Can you use sand to thicken EPOXY? For I plug I want to spread thickened epoxy along an edge because the fiberglass cant quite bend to the exact shape. I have heard of colloidal silica filler for this, can't I just use sand? or crushed up dry clay? |
| It would be heavier than all get out, and you wouldn't be able to work it after you did it, it would tear up any tools that you tried to use to cut it. Much better to use wood flour or sawdust or something like that. |
| You could use flour or talc, what ever you can get the cheapest. But if you need easy to sand material then you have to spend money on microspheres. |
| Sand is also way too large on an order of considerable magnitude, for use as a filler material. Why sand and what is it's primary goal in the matrix? |
| Or why not just use the colloidial silica? its not expensive. Steve. |
| Sand will be heavy --if thats a concern . I have used rice and sago infact there is many products on the supermarket shelf can fil out some resin / epoxy. |
| Sand will also be imposable to sand down well. |
| I can see using sand in a plug to fill really big holes. You can then use fumed silica or other more easily worked filler for final fairing.
__________________ Gonzo |
| Sand will NOT sand down in a mold of anything. You are going to use sand in a problem area ? If it is TOTALLY OUT OF SIGHT & NEVER needs to be sanded or removed ???? You can use anything. |
| jeremy,if you weigh the cost,youll find the colloidal thickeners are much less expensive than sand or clay when you have 100 ft of lake under you,and your further from shore than your swimming abilities allow.there are great brands out there,i use west system, mostly because thier online assistance is ideally suited to a novice like myself.this site is also one of the best sources of info ive found |
| I just need the thickened epoxy to fill the hard corner where the bottom of the plug meets the flange board. It's not for a Boat. I could use flour? Has anyone ever used flour |
| The answer to this would simply be no..
__________________ Capt. John Banister, Marine Surveyor Palm Beach Gardens, Florida www.SuenosAzules.com |
| Jeremy, you could use many things such as West-System filler, silica, and yes even rice, but sand would be at the bottom of my list of things to use unless I was in a pinch and had limited resources. I have worked with epoxy and fillers in my younger days working in a boat yard on custom fiberglass boats and many things were sometimes rigged, but sand can be course, wet, and dirty to have a good adhesion to it.
| strip or sand | pasty63 | Materials | 10 | 12-19-2010 08:46 PM |
| How do i sand an inside curved surface | wet-foot | Materials | 13 | 06-13-2010 09:25 AM |
| Sand Blasting and Glass Repair | ryanpratt | Boatbuilding | 3 | 02-11-2010 05:07 PM |
| To sand or not to sand, that is the question…. | SeaJay | Fiberglass and Composite Boat Building | 4 | 07-03-2009 08:11 PM |
| A sand bagger - strip-planked | DanishBagger | Fiberglass and Composite Boat Building | 28 | 02-21-2006 03:08 AM |
