Old 06-08-2010, 05:17 PM
souljour2000's Avatar
souljour2000 souljour2000 is offline
Rep: 156 Posts: 416
Can you paint or epoxy over old ABS liner?
I was wondering if anyone had ever had occasion to try and paint ABS liner like you see in older cars,boats and aircraft, etc. My early seventies boat has it for the hull shell liner and it is starting to look pretty rough.especially with old holes from installations and so forth...I want to epoxy fill the holes and perhaps paint this liner with a good oil enamel but I am not in a hurry until I'm sure it's the best approach..Thx..Morgan
Old 06-08-2010, 05:23 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Maybe this will be useful.:
http://findarticles.com/p/articles/m...5/ai_n8886774/
Hoyt
Old 06-08-2010, 06:40 PM
Rep: 156 Posts: 416
Thanks for the article...i grew up building model planes and tearing parts off of "trees'.I never new that it was the stuff was actually ABS though and injection-molded the same way...I'll try the oil enamel..always liked rust-o-leum oil enamel...the smell reminded me of my old hobby paint!...lol...Thanks again!
Old 06-08-2010, 10:57 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
It should paint fine, I would think you want to sand it first so the paint will stay attached, and of course clean it real good.
I am not sure I would use epoxy on it, there are ABS solvent glues that can be used to install "patches" or plus in any holes, might stay bonded better than epoxy.
Good luck.
Old 06-08-2010, 11:10 PM
Rep: 156 Posts: 416
Thanks for your reply Petros...I agree that fairing it with epoxy is a bit much and not needed...In retrospect I think you are right...just patching and painting should be fine...glad you mentioned ABS glues..I think that you are also correct about that...I think I can find some ABS specific glue..they used ABS for awhile for sewer pipe and other applications and joined each piece with glue I am sure..,probably still some around at plumbing supply stores....or there will be other application glues special to ABS that I should be able to find and hopefully sand after doing the patch.Thanks again..
Flat camo Paint over epoxy WesS Materials 8 02-03-2010 09:02 AM
Paint over Epoxy Manie B Boatbuilding 4 09-11-2008 06:10 PM
apply'n epoxy paint to hull.. harveydoryguy Fiberglass and Composite Boat Building 0 04-28-2006 12:26 AM
Epoxy, Paint, or what??? Mr V Wooden Boat Building and Restoration 13 01-08-2005 06:45 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 02:22 PM
