| can lapstrake planked boats stay on shore for winter storage or more? hello, i intend to buy a second hand boat. i found a lapstrake planked folk boat. and i have a land near the sea that i can store it for long periods when i will not use it. i think it is not suitable for carvel planked hulls, because the boat shrinks if it stays too long on shore. and if you put it on the water without caulking it will sink. is it the same for lapstrake planked hulls? cheers |
| Yes in principle! |
| There are several things you must do to prevent the wood from excessive drying. You should place the boat over dirt, the kind that doesn't pass water so easily. Something that grows grass well. A constant dampness is good for the hull. You should completely cover the boat. The sun can do a lot of damage, and wind can also excessively dry a wooden hull. If you cover it so that the cover encloses the area below the boat, all the better. Allow for a small amount of air flow, but not too much. You should also make sure the hull is well painted. Paint slows the process of moisture give and take. Bare wood shouldn't wait til spring. Finally, the bilge should be clean. When there's a storm, the winter cover can be blown off and no one but you will care if it does. It's up to you to go and inspect it. Rain water should not be allowed to enter the bilge, so cockpit drains should be checked for debris that would allow the cockpit to fill and flow into the cabin in case the cover gets damaged or blown off. Clean the bilge while the hull seams are tight, right before hauling if possible, not months later after the seams have opened some and the bilge debris has entered the seams from the inside. This will prevent problems down the line. Wood likes slow changes. Everything you do should work towards a slow exchange of moisture content. Good wood can deal with this slow change and usually, if the change isn't too extreme, such as years in a very dry climate, the wood will return to its original shape and condition. Narrow strakes do better than wide ones since the expansion/contraction limit is less. Garboards are widest so they need the most protection--- paint, sun/wind protection, and bilge inspection. Spend well on the cover. Plastic tarps are fine for fiberglass boats, but get a good acrylic tarp if you can, one that can stand some bad weather without tearing. Canvas is good too, but must be allowed to dry out on its own, which may be a problem if in contact with the ground. |
how should i cover it? complety cover like a package, round the bottom, or the cover will be like a skirt should its keel touch the dirt, or damped ground? cheers |
| Hello, may I hack this thread to ask Alain (and others with hands-on experience) what is their opinion on epoxy-coated wooden boats' behaviour under the same conditions? Did you ever notice a formation of surface cracks or other indicators of wood shrinkage on hulls left unattended outside? I'm asking this because I've read and heard some claims about glassed boats' weather-resistance which sounded to me like quite over the top. |
| You won't take advantage of the dirt unless you take the cover right down to the ground. Allow for some air gaps here and there, and an exit vent higher up as well. |
This is why it's not a good idea to epoxy-coat large chunks of solid wood, since you couldn't afford the incredible glass thickness required to keep it from distorting. Plywood should, if properly epoxy coated, weather like a fiberglass boat does. Fir plywood ought to be glassed as well due to it's hard/soft grain variation because the soft grain has many times the expansion potential of the hard grain, and there's no preventing it except to protect it behind a good 9 oz or so layer of glass. The problems are moisture exchange and heat/cold cycles, but with epoxy (completely sealing the wood both outside and within and every edge), it's temperature variation that's left to effect wood. For this reason, a tarp should be used to keep the boat protected from the direct rays of the sun. This does a lot of good where paints concerned too. Temperature variation can cause the wood joints to "telegraph" through the glass to the surface, but it's not a structural issue, just an aesthetic one. It's not too common either, mostly due to light glass being used, and most common when the wood isn't sealed with epoxy inside. The most important consideration of all is moisture exchange. I can't over-stress the need to seal the wood as near completely as possible if using epoxy. Light colors also help. Black absorbs far more heat than white, flat finishes more than glossy. You spend a lot on epoxy and glass and labor. Back-coat a plywood deck with epoxy before installing, edges too. Laminate together small pieces instead of big ones in a keel, for example, if sealing with epoxy. |
| Great info, thank you very much! |
After some 50 month the accommodation was pretty dusty but nothing else has shown any sign of wear and tear. The exterior was just rinsed, waxed and buffed and off she went. But of course that was a new boat and a wood epoxy laminated, not just a older vessel covered with goo and glass. Urisvan where around in Istanbul are you? Maybe I can assist you. Regards Richard |
| yes. apex1, i am in istanbul. i would be very glad. looking forward to hear from you. ulas risvanoglu |
maybe epoxy should be use as a water/damp barrier. and a thick epoxy-glass laminate can be a better barrier. these were what i believe and they can be wrong. i will be glad if you enlighten me. Quote:
regards ulas |
It makes no sense to seal only the outside surface because wood can expand quite a bit (and also shrink quite a bit) by taking on or giving off moisture through inside surfaces too rapidly. The bond to epoxy can shear off against the outside surface if the piece has enough design flaws such as being too dimensionally large, of certain reactive species, of hardwood, and if not sealed on every surface. it follows then that one should tend to epoxy thinner and smaller pieces, of quarter-sawn wood, preferably softwood, and seal all surfaces. |
| thanks a lot. and last question: which one is better; leave the boat on the water all the time or store it ashore in winter with a proper cover on it? regards |
| Ocean Waves as they reach the Shore | brian eiland | Open Discussion: All Things Boats & Boating | 3 | 05-27-2009 02:00 AM |
| Strip planked boats and saildrives? | Omeron | Sailboats | 5 | 05-06-2008 12:18 PM |
| Winter Storage | erie1 | Powerboats | 6 | 09-26-2006 05:50 AM |
| Mast stay | Ari | Sailboats | 13 | 04-05-2006 05:56 AM |
| Fiberglass expert on eastern shore | KBbricker | Fiberglass and Composite Boat Building | 2 | 08-17-2005 03:30 PM |
