Old 10-21-2006, 07:06 PM
Tiara3100 Tiara3100 is offline
Rep: 10 Posts: 4
Building Spray rail... What wood??
I have a 1984 31' Tiara that is a rather wet boat in a chop. I would like to add a spray rail to the hull. I have looked at some for sale on the net (Smartrail) and have decided that I would rather build my own.
I plan on making it out of wood and the epoxying/screwing it to the hull and then glassing it over. The shape of the wood will be similar to quarter round moulding, probably 3" by 2.5". The wood needs to be strong yet bendable enough to shape. Any suggestions?
Old 10-21-2006, 10:58 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
My favorite wood for that application is polyethylene, it's bendy, and not prone to splitting, cracking or rotting. If you insist on real wood, then a varnished piece of teak is never wrong.
For a glassed over rail I would use divinycell foam shaped to fit, and I would grind away all the gelcoat and mat down to the first roving 3-4 inches above and below the rail, so you have a shallow recess where the tabbing lands.
Yoke.
Old 10-21-2006, 11:04 PM
Rep: 10 Posts: 4
where would I get polyethylene in the correct shape?
Old 10-22-2006, 09:34 AM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
If you want to use wood, Honduras Mahogany is good. It is dense, takes fasteners and glue well, and it holds an overwrapping laminate.
I have also recommended the SmartRail to a number of people, and they all report very good success with it.
For an interesting article on the lifting strake modification to Blue Bill, a Wilbur 34, you can visit my website at: http://www.sponbergyachtdesign.com/Bluebill.htm
I hope that helps.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
Old 10-24-2006, 09:38 PM
Rep: 10 Posts: 4
Thanks Eric...
Building a wood rudder Eagle Boats Wooden Boat Building and Restoration 1 09-01-2006 10:38 AM
Lightweight building with wood? T Sailor Boat Design 8 05-01-2006 03:22 AM
Spray 40 Foot, Bruce Roberts Design, Mahogany (Wood), Sailing Yacht, Hull jedclampit Marketplace 0 02-25-2006 01:43 PM
Spray rail design nevd Boat Design 9 05-06-2004 07:50 PM
Chine & Spray Rail Geometry Boat Design 5 04-25-2004 07:27 PM
