| Building blocks for mould/plug construction? Hi All, I'm trying to find out what options are available for constructing a base for composite moulds and plugs. Often people use materials with a density similar to polystyrene, they carve/route that then apply a tooling paste to do the finishing cuts. Sometimes on larger projects a wood frame is constructed and foam and/or tooling paste is applied over that. Is there any modular reusable systems? I was thinking of something along the lines of an industrial version of Lego (as in kids toy Lego) building blocks. Cheers Splint |
| Clipship Splint, quite a few years back there was someone down the coast marketing something called clipship, it was like some kind of interlocking strip plank that was set up into female station forms to make a temporary mold, I only saw a vague photo in a magazine ad so thats all I know about it except that the surface still required some sanding & that it might have been in Bomaderry or Nowra. All the best from Jeff. |
| wood and fiberglass,, and put splits in it anywhere you want, then bolt together and bolt apart as needed.paint everything with tooling gel,and prep properly.it'll be strong, sturdy,movable, and easy to repair when ya get a chip in it
__________________ hehe ,,,,,Jim------> |
| i need to know how to make a fiberglass or composite plug or mould need help badly | Islandboy | Fiberglass and Composite Boat Building | 6 | 04-06-2006 07:17 PM |
| Plug and mold construction | sandman1984 | Boatbuilding | 3 | 12-23-2005 08:08 PM |
| Mould less fiberglass construction | RAVenous | Fiberglass and Composite Boat Building | 10 | 11-24-2005 10:55 AM |
| Mould construction in Poland | Maciej | Fiberglass and Composite Boat Building | 0 | 01-22-2005 01:25 PM |
| Help for plug construction by CNC | Malena | Fiberglass and Composite Boat Building | 26 | 01-22-2005 11:01 AM |
