Old 04-07-2009, 05:34 PM
soccerrj88 soccerrj88 is offline
Rep: 10 Posts: 2
Building a 3 point hydroplane from plans
Hello to all... I'm looking at building a 3 point hydroplane as a hobby. I have found the plans for 3 different types or just different plans. They're called the Hasty Hydro (http://www.muskokaseaflea.ca/staticw...d=60&Itemid=41) , Scat Cat - (http://www.svensons.com/boat/?p=HydroPlanes/ScatCat) , and the Saucy Shingle - (http://www.popularmechanics.com/outd...g/1277141.html). Has anybody built one of these? About how much does it cost? Time? What would be the expense and time difference between the hasty hydro, that just calls for a plywood sheet and build up from that and the other two that require the framing with plywood covering it? I plan on powering it with a '96 8hp Johnson that I already have as a dinghy motor. This is just supposed to be a low budget first build hobby b/c I've always been interested in building boats and I just went to a APBA race where they had little pickleforcks, so I found these free plans, and I'm hoping to get a chance to build one but money's a little tight. So I'm not looking to spend to much money. I don't plan on fiberglassing the whole thing, just the edges is what the plans call for with some fiberglass tape and resin. I plan on using Marine grade AB plywood. Whats the cheapest way to seal the plywood. Just paint a resin over it without mat or cloth or will it be alright to just use on the lake once in a while without sealing it? Does anyone have some finished pics that aren't from 1960's B&W or have any insight on which would be better from the three or even plans I haven't found that are cool. The plans call for Fir, but that's kinda hard to come by here and really expensive if I could order it, so what would be another good strength to weight ratio wood to use for this that is cheap? Thanks for the info.
Old 04-08-2009, 12:09 AM
Rep: 10 Posts: 2
Nobody??? Just ideas on any 8.5' 3 pointer?
Old 04-08-2009, 02:32 AM
Rep: 2891 Posts: 8,792
https://www.boatdesigns.com/products.asp?dept=366
Looking for an old Ventnor hydroplane or plans for one banshee880@comc Boat Design 10 07-25-2009 03:50 PM
Small Hydroplane centre of gravity/balance point?? Sooty Boat Design 3 12-28-2007 05:05 PM
building a hydroplane boat/help Jasonkatie Boatbuilding 11 12-28-2007 05:29 AM
Building X1 Cabover Hydroplane Need Pics Thin water Wooden Boat Building and Restoration 10 06-07-2007 11:41 AM
hydroplane plans suggestions? gilligan123 Boat Design 4 08-07-2005 10:13 AM
