Old 12-20-2006, 03:02 PM
SCUBAnut SCUBAnut is offline
Rep: 10 Posts: 9
Buffing gelcoat to match the original
I've made several small gelcoat repairs, but can't seem to get the gelcoat to buff out to the original gloss. I sand with 360, 400, 600, 1000, and 1500 to get as smooth as possible. Then I buff with a 7" buffer at about 2000 RPM using compound from West Marine. It seems a little better if I use the 3M Finess compound. It just doesn't buff out as glossy as the original. Are all manufacturer's gelcoat created equal? Should I add white pigment to the gelcoat? What's my problem, am I expecting too much from my repair?
Old 12-20-2006, 05:34 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Are you talking shininess or color?
Old 12-20-2006, 06:16 PM
Rep: 10 Posts: 9
Shininess, I guess getting the exact shade of white is another issue.
Old 12-22-2006, 11:21 AM
ondarvr ondarvr is offline
Rep: 226 Posts: 636
If the repair is not fully cured you may not get a good gloss and if you do, it may not last long. Make sure you catalyze it at 2% and it needs to be warm for it to cure correctly, 70F + if poosible. If you thinned the gel coat to spray it, or thickend it to use it more like a putty, it can (may) reduce the gloss. There are differences in gel coats, some repair very easily, some don't, when you buy gel coat at most retail outlets you don't really know what you are getting. There are only a few companies that make gel coat. They sell it to other companies that repackage it into smaller sizes and put other labels on it, many of these companies switch suppliers frequently looking for a lower price. Also gel coat has a shelf life, 3 to 4 months is normal, the older it gets, the more chance you have of it not curing correctly, sometimes the stuff on the store shelf has been there for a year or more.
Bavaria Match 42 lost its keel... ErikG Sailboats 82 05-28-2006 03:45 PM
Bavaria Match 35 Keel Profile koc Boat Design 5 05-02-2006 04:00 PM
Rolling a cone shape to match transom contours... Revisionist Metal Boat Building 3 01-11-2006 08:28 PM
engine/propeller match dave kibble Propulsion 4 10-06-2005 04:08 PM
Scanner used to match gelcoat color jbrown15 Materials 0 04-13-2004 12:10 PM
