Old 10-19-2005, 09:19 PM
paularey paularey is offline
Rep: 10 Posts: 32
Is brushed on waxed gelcoat a good bilge coating choice?
I have a catamaran (fiberglass hull) I would like to touch up a bit in the bilge & locker areas. Would brushed on waxed gel coat be a good choice? Or overkill..? The areas a rarely ever wet but I still would like a durable coating. Not real concerned about a flawless finish.
Much thanks
Paul
Old 10-19-2005, 09:47 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
I'd be worried here about the gelcoat not bonding perfectly and thus encouraging osmosis. If the surfaces aren't excessively rough, Interlux Bilgekote is a good choice for this; it's not the prettiest stuff (kind of a flat grey colour) but it's good at taking abuse, oil, fuel, bacteria, algae, etc.
Old 10-22-2005, 06:29 AM
Rep: 700 Posts: 3,208
If you can get it clean of old oils any 2 part EPOXY would be good choice.
Just be sure to scrub the epoxy surface down with detergent & water a couple of days after it hardens.
FAST FRED
Old 10-24-2005, 11:50 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Bilgekote.
Yoke.
Old 12-03-2005, 04:32 AM
Robjl Robjl is offline
Rep: 10 Posts: 90
Don't use flowcoat.
A two-pack polyurethane or epoxy would be better.
Old 01-25-2006, 04:40 PM
Darren Darren is offline
Rep: 10 Posts: 11
Gell Coat is absolutley fine.
Ensure you mix in 2% Wax Solution proir to adding the catalyst
Ensure you abrade the area you intend to cover with 80 grit, vacuum the dust/debris and then wash the area using acetone.
We have been using this system for many years on hundreds of boats
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
