Old 09-03-2004, 09:09 PM
Jmooredesigns Jmooredesigns is offline
Rep: 10 Posts: 10
which brand structural adhesives
i am building a 10ft long by 5ft wide boat and have come to the conclusion that the deck and hull joints will be attached with a structural adhesive. i am aware there are many choices however i want the best for my needs? my boat is rated for 450lbs and is not rated for propulsion. so what would be the best choice? i am considering sikaflex 292 or a plexus brand (high dollar stuff) but i hear the best available and i want to rest at night knowing these hull and deck joints wont come apart. were using a shoebox type joint and can have aprox 1" height of sealant that will be 1/8" thick. can anyone give me an idea of what would work best even if theres another brand out there i havent considered?
Old 09-05-2004, 01:17 PM
jammer's Avatar
jammer jammer is offline
Old, bald and ugly
Rep: 10 Posts: 44
Plexus is top notch material. It's physicals are aerospace grade. Though 1/8" is a little on the wide side, at the size and weight capacity of the boat, this shouldn't be a problem. Worth the cost. As an alternative, also investigate Lord Adhesives.
Old 09-09-2004, 07:49 AM
Rep: 66 Posts: 640
Use the sikaflex, put in some screws and seal the joint with a layer of glass, you'll be fine.
Dutch Peter
Old 09-26-2004, 11:11 PM
tja tja is offline
Rep: 11 Posts: 125
look at 3m brand 5200 adhesive.
Test results on various adhesives JimCooper Open Discussion: All Things Boats & Boating 4 07-25-2005 11:09 AM
Methacrylate Structural Adhesive Thunderhead19 Boatbuilding 13 09-28-2004 11:19 AM
Adhesives for certifoam pontoons? TC TRAV Boatbuilding 3 08-28-2004 01:18 PM
