Old 12-10-2001, 08:42 AM
firstflight firstflight is offline
boxed floatation foam
Can anyone tell me the names of manufactures of block floatation foam that is compatable with polyester resins and has gasoline resistance. I am building a 72ft.6inch trimarand which the foam will be both mold and floatation support of the hulls. I appreciate any help.
Bill
Old 12-10-2001, 06:13 PM
Scott Scott is offline
Registered
Rep: 10 Posts: 41
If you have a large budget and the foam is going to stay as part of the hull, the stuff to use would be either an Airex or lightweight Klegecell foam. But these are both pretty expensive.
Divinycell- http://www.diabgroup.com/ or
Klegecell - http://www.diabgroup.com/
Herex - http://www.alusuisse-airex.com/products/e/100/130_e.htm or http://www.baltek.com/airlite_herex.html
or Corecell.
In general if the foam has to stand up to polyester resin and gasoline polystyrenes are out and you are looking for a urethane foam.
Old 12-10-2001, 07:19 PM
Registered
Rep: 10 Posts: 41
Someone else suggested taking a look at the Aircraft Spruce & Specialty catalogue for some ideas on foams, http://www.aircraftspruce.com/ and specifically
http://www.aircraftspruce.com/catmai...t=catorder.php
Their prices aren't cheap, but they offer a good variety.
Old 12-10-2001, 07:25 PM
Registered
Rep: 10 Posts: 41
And as far as cheaper sources, Polyurethane typically comes in 4’ by 8’ by x number of feet blocks called ‘buns’ I believe. They will slice it to the thickness you want at a cost of around $15 per inch of thickness in a 4' x 8' sheet. Sign companies use sheets up to a few inches thick. For thicker you would want to look for a commercial insulation or refrigeration company or contractor.
Old 02-19-2002, 01:16 PM
keith keith is offline
Rep: 10 Posts: 3
You can use polyurethane foam in sit. material, but that would mean creating a mould for the foam. The other way would be to buy the block form, or create a block your self and carve it. the urethane is petrol resistant. Buying the foam in two pack is not that expensive and you can designate the density and characteristics.
floatation foam Lew Morris Materials 5 10-25-2008 05:42 PM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 09:19 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 07:21 PM
Positive Buoyancy Floatation foam & Ullage Equation trouty Boat Design 2 07-02-2004 10:29 AM
Using floatation foam to keep a dingy inflated Guest Boat Design 2 07-28-2003 06:12 PM
