| Because of the thickness of the truss, you could double wall that with inexpensive plastic. It would heat a whole lot easier, and less of that 'rain'. |
| I just got the plans from David yesterday and i think he suggests double walling it for that reason and also putting plastic down on the floor, i think Knotty Bouys put plastic on the inside of the trusses. Steve. |
| I think I'll build some stem walls to increase height, and still stay under my county's permit requirements. I can go 576 square feet without a permit, 18x32. |
| Building up some knee walls is an easy way to gain height. I've seen that done on pretty much every commercial sprung structure the farmers use. I lined mine with Tyvek and plain black plastic. The black plastic goes up about 5 feet and then tyvek above that. Don't ask me why, i don't know why I did it that way other than the white tyvek is better for lighting. You should cover the floor if building over dirt. Most of the humidity you'll get inside will come from the dirt floor. ![]() ![]()
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| I probably wont be building the bow roof shed as i need about 30ft width but i may do one for other smaller projects. Steve. |
| I will probably do some welding in there, so I would put down a vapor barrier and a couple of inches of gravel as a work surface. I think that would do it. |
| KnottyBuoyz, how did the shed fare over the winter? |
| It's just gone through it's second winter. Still standing. There were a few rips from wind storms but Gorilla Tape fixed those up enough to get me through at least another winter. The shrink wrap plastic might not of been the best choice but it was significantly cheaper.
| Thank you very much, this is priceless information. Were the rips just storm stress, flying objects (I can situate mine away from the trees fairly well), frozen snow/ice, or does it look like the UV is taking it's toll? |
#25
The rips I had to fix were just wind damage along the bows. Sometimes you get a little too much heat in one spot and it shrinks really thin. Not totally unexpected. Largest was 2' long maybe. Heat sealing the seams works really well, I haven't had a seam let go yet. I figure this should last another two winters anyways. My biggest fear is wind getting underneath it and it taking off! Just anchor it well and seal it all the way to the ground and you should be ok.
#26
Having a 16x36 shop without tax penalty for 10 years is priceless. |
#27
| My "temporary winter garage" was not nearly so elaborate as Rick's Taj Mahal. I used wood cut from the local forest, made a bridge over the boat. Put the Clear plastic tarp on first. The Clear is waterproof but dies easily out in the weather. Then the Blue tarp. The Blue will leak eventually, but it will withstand the weather. Where the Blue tarp came to the ground, I rolled the edges up in a small log, then staked it down, then Piled Dirt up the first foot or so. That kept the wind from going under the tarp. I also used "tensioners" made of plastic jugs half full of water, to keep the tarp taut. Rick's has lasted two winters, and still in use, where my whole cover went into the burn pile each spring. I think doing it Ricks way is good because it can be re-covered year after year |
| Ideas/Plans for a boatbuilding shed? | Jay and Ebben | Boatbuilding | 37 | 01-21-2012 11:02 AM |
| Sodeb'O Out of Shed | Chris Ostlind | Multihulls | 3 | 05-04-2010 08:43 AM |
| I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but | Squidly-Diddly | Boat Design | 4 | 08-23-2009 06:08 PM |
| Planing bow hull and getting over the bow wave hump | kach22i | Boat Design | 2 | 04-03-2007 03:51 PM |
| 47' sloop/shed/tools for sale as package deal | 47' sloop | Marketplace | 3 | 08-14-2003 09:36 AM |
