| Would Sicaflex or 3M 5200 not be a better choice for this? -Tom |
| To me carbonizing it means scorhing it. This is not neccesary. Sch 40 PVC will lose its gloss with a torch ever so lightly passed over the surface. More difficult to describe than observe but the surface will change slightly and be less glossy. Then sand it and the bond will be stronger than the PVC itself. This is from West System's Tech support. They have done distructive testing on various epoxy/pvc bonds and this was their reccomendation. They will gladly forward you the test data. This technique does not work the same with Sch 80 PVC. We glue Sch 40 pvc regularly and have had good results, both with andwithout flame treating.We abrade with 40 grit for a good mechanical bond and if the joint needs extra strength we will flame treat it. |
| Agreed David, it's more of an oxidizing process then a true carbonizing. You're not looking to burn the plastic, but just change the surface molecules a bit. |
| Um..this is interesting...kinda wondered about how epoxy would work...with any vinyl really...and also wondered specifically about PVC...so anyway..I'm gonna go and try PAR's recommendations..and the other guys who also said scratch,groove, and sand, more or less...from my own experiences..that would certainly seem to be the way forward with PVC and epoxy...asa plumber..I would say that purple primer may help too...but then flame as PAR suggested is accomplishing same thing...IMHO...would clean the carbon off well though...and finalize "etched/scratched/burned " PVC with acetone...
__________________ ] |
| I will check the plumbing shop for PVC primer. Local painter told me he flame treats pvc if he must awlgrip it. . To test the flame treatment, run water over surface . If the water beads the flame treatment has not been succesful. The water should sheet off the flame treated surface. Guess I need to test a bond. The PVC will be mounded as skids on a tender storage sled. |
| It's okay, just ignore my input, I'm used to it, I don't mind, really, carry on, it's fine, no problem, go ahead, silly me, what was I thinking, I have nothing to add, as you were, really, carry on, it's okay, I'm good. -Tom |
| No ,Sika wouldnt be a good choice in this application. These pcv sled runners need to be rugged. I was hoping to split the pvc in half...a half round section... then run a generous Epoxy fillet to bond the pvc to the plywood tender sled. . |
| HDPE pipe is a lot more "slippery" and tougher than PVC, if that is the type of service it is going to see. Probably harder to glue to than PVC though. C.O. |
| Of the hard plastics, such as PVC, styrene and ABS, a heavy tooth and "oxidizing" the plastic, just before epoxy application is the best route. The solvent used in PVC primer is usually MEK which will adversely affect the epoxy, it's cure and physical properties. Solvents used with PVC, are to literally change the surface molecules on PVC, so that the cement (which really isn't) can create a chemical weld. As to the use of polyurethanes like Sikaflex 292 or 3M 5200, you'll not be as satisfied with the results, so wouldn't be recommended. The elongation properties of these products would tend to help work the surface bond loose, unlike a more rigid material like epoxy. I've had very limited success bonding epoxy to the HDPE and UHMWPE. These self lubricating plastics, resist all but heat and chemical welding. I have used epoxy and mechanically keyed HDPE to it, with the use of a multiple dove tail slots, which the epoxy keyed to, but this is a purely mechanical attachment, even though there was some surface attachment involved. |
#25
| Iv'e just epoxy'ed PVC to plastic with just giving both surfaces a sand and it's rock solid 5:1 mix. |
| Building a raft w/ pvc pipe? | Aberamonli | Boatbuilding | 31 | 01-08-2012 10:23 AM |
| 4 inch pvc pipe raft. | rickjames | Boat Design | 17 | 07-13-2009 11:40 AM |
| PVC Pipe Canoe | camping nut | Boatbuilding | 19 | 09-22-2008 12:42 PM |
| fiberglassing PVC pipe?? | georgiahemi | Boat Design | 5 | 10-05-2007 06:05 AM |
| 150mm pvc pipe | jgfish | Materials | 17 | 01-23-2007 08:16 AM |
