| Bomar opening port gasket I seem to remember a thread on hatch or port lens replacement but am unable to find it, maybe someone can lead me to it. If not,i have a boat in the shop that needs new lenses in 9 series 3000 extruded ports and have talked to bomar and apparently the oem gasket is no longer available,they do have a different gasket of which they are sending me a sample of but it is meant for use when you are just replacing the gasket, you cut off the old bulb and peel and stick the new one, im a bit skeptical. The oem gasket i believe had a lip that glues into the frame along with the lens. I guess what i am looking for is if anyone has done this same job and has a scource for a suitable gasket more like the oem one. Steve. |
| What country do you live in?
__________________ Gonzo |
| USA,midwest. Steve. |
| What do you call a "bulb".
| opening construction | Sudarikov | Boat Design | 4 | 07-01-2007 04:03 AM |
| Opening the belly of the Beast | Deeman | Boatbuilding | 29 | 10-22-2006 08:40 PM |
| Mercruiser 302 Head Gasket? | n0dih | Gas Engines | 3 | 08-08-2006 11:59 PM |
| transome plate gasket leaks | tjmahon | Propulsion | 0 | 07-09-2006 11:12 AM |
| Use "Everseal" gasket for sealing... | Nervous | Boatbuilding | 0 | 03-31-2004 10:45 PM |
